Overheating 300, Help!
Put on Offy intake, used the FI exh. manifolds, had a 2 into 1 exhaust, 2.5" all the way out.
New water pump, t-stat, hoses, flushed rad. was running good, didn't seem to have the power it should, truck has 4.10's but I also have 255/85/16's. Always ran warm in summer, going up Deadwood out of town to home, would spit up if I put to much a-freeze in. Loaned to buddy over winter, he brought it back, I drove to work, was going to go cut wood after work, on way up hill started getting hot, then pegged, blew head gasket.
Trailered her home, pulled head, broken head bolt where head gasket blew, when removing head bolts, all "felt" like different torque,, some hard as hell, others not so much. Head straight-edges good, doesn't seem to be warped or bowed, found out it is punched .030.
So, question is (finally, I know
) because it was FI, is the cam timing different, what would make her run hot, all the passages look good, I think I put a 180* t-stat in, don't remember. Are there differences in the heads from carbed to FI?My last 2 300's I had dual outlet headers and ran duals all the way out, is it choking for not enough air flow out?
Any and all thoughts please!
I put the thermostat in backwards and it ran super hot, like bend the needle on the temp gauge hot. As far as overheating goes that seems to be a common snafu.
Are there different heads from FI to Carbed? Some of the cooling passageways in the head don't go into the block? Are there different blocks for FI? Older block, newer head?
I hope that new head gasket AND new head bolts TORQUED correctly, will take care of it, I am going to check my t-stat, I thought I put a 180 in, but you never know, I will write it down this time!
Last time, I used an ARP stud set I got from eBay for 30 bucks and a severe duty head gasket. No problems since.
I'm convinced the headbolts caused the problems initially.
Thanks for the info guys!!
Just a 12" glass pack and 2.25 or 2.5 all the way out, has a nice raspy bbbbrrrrrrappppp up and down! Thought about trying a flowmaster I have in my shed on it, just to see if I like it on the 6.
