Window Switch
Old Apr 10, 2011 | 03:33 PM
daner01's Avatar
daner01
And yes the driver side didn't work before the swap. Not sure if I was clear or not...
Old Apr 10, 2011 | 04:10 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Originally Posted by daner01
It started out intermittently and it liked to roll down more then up and then one day it quit working all together. I ripped the door apart thinking it was a motor and on a hail marry I swapped them and it fixed it. the driver side master worked and the passenger worked. the driverside still won't roll down the now dead back passenger. swapping switches is easy so I would hive that a try. let me know...
So u just swapped the switches then...... i will give it a try prolly not today but this week. thanks for the help i will keep you posted
Old Apr 10, 2011 | 08:15 PM
jrf250's Avatar
jrf250
You could check a junk Yard for another switch if that is Your problem. They use the same switch in F150's and Expedition's. It is the same as the power mirror switches. I got one out of and Expedition in My truck right now.
Old Aug 6, 2011 | 03:56 PM
jcrammell's Avatar
jcrammell
Originally Posted by bakerbuilttracks
ok i just found a thread that told me i could take out the motor and push up the window. so i went out and took the motor out and slid up the window. in the same thread it told you how to take tho motor appart and clean the brushes. i took the motor appart cleaned the entire motor put it all back together. plugged it in and i still have the same prolbem. it will roll down but will not roll up with the passenger side switch. the switch on the driver side will not do anything for the passenger side window. im wondering if i shoul get a new motor? or is ther something else going on. Because like i said...... using the driver side switch to roll the passenger side window up or down dose nothing at all. the passenger side switch will roll the window down but not up.
Do you know where that write up is at. I haven't been able to locate it yet.
Old Aug 6, 2011 | 04:05 PM
tdpower's Avatar
tdpower
This thread might help. I also linked Nolan's write up in the thread.
https://www.ford-trucks.com/forums/9...with-pics.html
Old Aug 6, 2011 | 05:20 PM
351Cleveland C4's Avatar
351Cleveland C4
i had a broken wire in the drivers door wire boot, (that big rubber acordion tube running from the cab to the door) it too would work when the wire ends touched together, but when they came apart none of the switches would work, i chased the problem for days, taking everything apart and making sure it worked. this may or may not be your culprit.
Dpan63
Apr 9, 2014 05:42 AM
pllckjsh
2004 - 2008 F150
Aug 28, 2012 07:45 AM
cableguy1224
19
Aug 4, 2009 12:24 AM
pablocruz69
Mar 28, 2009 11:44 AM
o9rady
1997 - 2003 F150
Apr 24, 2007 10:39 PM
