power window issue
Old Dec 13, 2011 | 09:53 AM
pllckjsh's Avatar
pllckjsh
power window issue
New to forum so please bear with me..... ok I just bought a 2005 f150 super crew the issue I am having is the passenger window will roll down from the passenger control switch but not up has to be rolled up from driver side.....also neither back window switch will operate Windows but when I roll them down from driver switches and hit the rear switch at the same time in opposite direction it will stop the window the rear switches are not lit up either any help is greatly appreciated
Old Dec 13, 2011 | 12:38 PM
86CJ7's Avatar
86CJ7
I have a similar issue but usually the switch is fine as long as it has not rained. Also if I just hold the switch for a moment it usually catches 2006 F150 crew cab
Old Dec 13, 2011 | 03:40 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Sounds like a problem with the drivers side switch assembly may be bad or have a short in it.
Old Dec 13, 2011 | 07:29 PM
Greg B's Avatar
Greg B
I had the same problem on my 06. It was a bad switch. Thus far I have replaced both driver side and passenger side window switches. I kept the old ones and cleaned them and they work ok. I'll keep them for backups. It must be a commen problem as most dealers in my area stock them.
Old Dec 22, 2011 | 02:53 AM
2006 F-150 FordSter's Avatar
2006 F-150 FordSter
hey that happen to my truck to but its the switch because i took the door panel off and replace the switch, its probably went out on your your just like mine but if you want a new one that buy one at a ford dealer, they sell them cheap but buy it online because they are cheaper. look at the prices down below
In stores: $160-$264
Online: $60-$150
Old Jun 18, 2012 | 06:23 AM
DaParm's Avatar
DaParm
Windows
My rear windows work from the rear switches but not from the drivers switch. I replaced the drivers switch and they still don't work from the driver's side, only the rear switch. What gives with that? I inspected the wires and they appear to be fine.
Old Jun 19, 2012 | 01:12 PM
1Aauto's Avatar
1Aauto
Former Vendor
Also check the wire harness between the drivers side door and the body of the truck to see if there's a frayed or broken wire. You could have two things going on.
We also carry the window switches for your 05 if you need to replace any of them. Here's a link to them on our website.
F150 Window Switch
Old Jun 19, 2012 | 05:49 PM
Jasondd's Avatar
Jasondd
both windows dont work .put hot wire they work
Old Jul 3, 2012 | 07:28 PM
clemtigs's Avatar
clemtigs
I've had similar problems with my switch in the driver side door. The switch uses a plastic button inside which gets worn down. I was able to take the switch apart and switch buttons with other windows. The down side is I can't roll down back windows from my control. It is cheaper than replacing the switch if you can live with it.
Old Jul 3, 2012 | 07:51 PM
rbell0's Avatar
rbell0
Mine had a bad drivers side switch on the up side. Usually happened when it was raining.
Old Jul 3, 2012 | 07:55 PM
Jasondd's Avatar
Jasondd
no power to none of the power wires in the door for the windows on either side , so just ran another wire from fuse box,problem solved thanks.
Old Aug 27, 2012 | 04:47 PM
bobminn's Avatar
bobminn
All 4 windows work from driver door - none work from passenger doors - have replaced master switch on drivers door - still no good ! Anybody have an idea what is the problem ? 2006 F150
Old Aug 28, 2012 | 07:45 AM
Greg B's Avatar
Greg B
You'll need to check the switches of the other windows. Most likely that's the problem. If you have a shop manual handy or can get one to use, it'll tell which terminals to check for up and down and you check continuity when the switch is pushed to either the up or down position. I'd check voltage to the switch as well. If you don't have access to a manual, just take one of the switches out, take the button off to expose the electrical contacts. Clean the contacts with electrical contact cleaner and re-assemble. Plug it in and see if it works. If it does, you've fixed the problem. There was a thread on this site about a year ago that illustrated how the switch comes apart. If memory serves me correctly, the passenger side switch was as much or a little more than the driver side master switch.
timbersteel
Sep 23, 2013 07:14 AM
emd160
2004 - 2008 F150
Dec 18, 2010 10:50 PM
Mish
1997 - 2003 F150
Feb 24, 2010 07:36 PM
BatteriesNotINCL
2004 - 2008 F150
Oct 19, 2007 06:30 PM
jrich14
1978 - 1996 Big Bronco
Dec 8, 2004 04:34 PM
