Power window mystery?
Old Apr 7, 2014 | 06:18 PM
Dpan63's Avatar
Dpan63
1999 E350. Went to roll down passenger side window from driver's side - nothing happens. Tried from passenger side switch and window will go down but not up. (rolled back up using spare battery). Switches are all the same and I switched them out and they all worked the driver side window, also cleaned them. So - switches OK, motor OK - what's the problem? Broken wire? Thanks
Old Apr 8, 2014 | 06:00 AM
JWA's Avatar
JWA
One of the PW circuits have failed---your motors are working as you've already demonstrated.
My best guess is one of the switch mounting blocks secured to the door trim panels has developed a loose female terminal---not all that uncommon.
It could also be the male contacts of the switch itself has become corroded--easily cleaned and re-inserted to test operation. Here's a photo:
If you'll be doing this sort of work yourself in the future get an EVTM which is all the schematics for your particular year, make and model---they're invaluable for such tasks.
Old Apr 8, 2014 | 06:13 PM
Dpan63's Avatar
Dpan63
Solved
Nope, broken wire. Did continuity tests and brown/blue wasn't right. More tests and it was probably in the boot between the door & chassis. Ran new wire and all is fine. Thanks for your response.
Old Apr 9, 2014 | 05:42 AM
JWA's Avatar
JWA
Good news then----thanks for updating us!
randomhero1172
Aug 2, 2008 09:21 PM
boonie
Electrical Systems/Wiring
Mar 8, 2007 09:33 PM
twabscs
1997 - 2003 F150
Nov 24, 2006 07:38 AM
Mike Earls
Nov 12, 2005 12:24 AM
vicv
May 1, 2005 04:26 PM
