EBP Sensor location?
Old Mar 4, 2011 | 01:33 PM
rdunagan's Avatar
rdunagan
Where is the ebp sensor and the tube? anyone have pics. the diagram i looked at looks to be the temp sensor. just wanna clean mine since its never been done and i have nothing to do at the moment
Old Mar 4, 2011 | 02:20 PM
BobsF350's Avatar
BobsF350
SENSOR MOUNTED vertical right next to the fuel filter housing and the thermostat.
look at the left exhaust manifold and youll see the stainlees tube coming off the front of the manifold
Old Mar 4, 2011 | 02:23 PM
rdunagan's Avatar
rdunagan
is it the one that is on the intake manafold
Old Mar 4, 2011 | 02:26 PM
BobsF350's Avatar
BobsF350
no look down between the air filter and the fuel filter
Old Mar 4, 2011 | 02:31 PM
rdunagan's Avatar
rdunagan
does the tube run up to it? or is it a wiring harness
Old Mar 4, 2011 | 02:46 PM
BobsF350's Avatar
BobsF350
tube runs up to a 45degree fitting the sensor is screwed into the fitting
Old Mar 4, 2011 | 03:36 PM
Gofigurethis_01's Avatar
Gofigurethis_01
On my '05 its on the driver-side of the motor straight down from the FICM. Can't miss it.
Old Mar 4, 2011 | 06:22 PM
cheezit's Avatar
cheezit
look at the drivers side exhaust manifold and find the olny tube that comes off of it. follow that tube North. at the end of that tube lays the all elusive EBP
Old Mar 4, 2011 | 06:35 PM
clane's Avatar
clane
how do you clean it ?
Old Mar 4, 2011 | 06:52 PM
cheezit's Avatar
cheezit
the tube can be cleaned with a coat hanger. the sensor is a replacement part.
Old Mar 4, 2011 | 09:25 PM
rdunagan's Avatar
rdunagan
sounds good found it thanks!!!
bigreentruck
Dec 13, 2016 12:37 AM
POS Camaro
Apr 25, 2016 11:04 PM
Jforce05
Dec 19, 2015 10:32 PM
Gatordog
Nov 25, 2015 09:20 AM
ehgeeray
Mar 26, 2010 09:12 PM
