EBP sensor
Old Dec 12, 2016 | 11:04 AM
bigreentruck's Avatar
bigreentruck
EBP sensor
Thinking of cleaning out/changing EBP sensor and tube in attempt to enhance running and mileage.
Anybody have input on aftermarket sensor? At $90 range for OEM, I'm hoping for a less expensive one that will last.
Old Dec 12, 2016 | 11:13 AM
knottyrope's Avatar
knottyrope
OEM only IMO
Old Dec 12, 2016 | 11:29 AM
AKHunter93's Avatar
AKHunter93
There are very few instances in which the OEM is not the best option for replacement parts on these trucks.
Old Dec 12, 2016 | 11:43 AM
kruc's Avatar
kruc
Any reason why you don't think it could be cleaned up to work well once again? Isn't that pretty common to just clean them up? I'm probably going to clean both of them on my truck this weekend.
Old Dec 12, 2016 | 11:52 AM
Rikster-7700's Avatar
Rikster-7700
Just to reiterate, OEM sensors only on these trucks, there have way too many issues with after market ones. Then you end up paying twice in the long term....
Old Dec 12, 2016 | 12:19 PM
coax9952's Avatar
coax9952
You can clean them up, Carb cleaner, brake cleaner, works great... DO NOT stick anything inside the sensor opening, there is a membrane inside that you will destroy and THEN you will be buying the $90 replacement. Check your OBD flavored program and compare Baro/EBP/Map readings, KOEO, if it's working correctly, your PSI reading shouldn't be more than 2 off....
Old Dec 12, 2016 | 12:52 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
OEM
OEM sensors only for our trucks. I tried to clean mine out with carb cleaner. I ended up buying a new one from Riff Raff. The tube is easily cleanable with throttle cable or weedeater cable and carb cleaner.
Old Dec 12, 2016 | 01:34 PM
Dirtscooter250's Avatar
Dirtscooter250
Another vote for Ford/International parts. Just talked to another friend who had an aftermarket EBP sensor go bad.
Old Dec 12, 2016 | 11:00 PM
bigreentruck
Will ck Clay at Riffraff. I could clean everything up as guzzle site details, but figured as long as I was doing it, might as well just replace it. I have 164K on clock and no prior history. Don't know how long they might last.
Old Dec 12, 2016 | 11:28 PM
bigreentruck
I can clean the tube if no issues.
Anybody know how long the sensors last?
Old Dec 12, 2016 | 11:45 PM
cj45lc's Avatar
cj45lc
IDK how long they last but mine was carboned up pretty good, I was able to put the part # in the search on ebay & got one in the sealed MotorCraft plastic for less than half the going price at the time. Seemed like the seller had quite a few of sensors from Ford, my guess he worked at a Ford dealer hahaha
Old Dec 13, 2016 | 12:37 AM
bigreentruck
Good idea, thanks for that.
L-ight
20
Nov 5, 2018 09:58 AM
comtb
Dec 31, 2016 02:59 PM
dothedew192
21
Mar 7, 2011 08:57 PM
natew
Jan 16, 2010 09:47 AM
wgw
Oct 15, 2006 08:16 PM
