low oil level in resivior
Old 02-18-2011, 05:32 PM
friskyjake's Avatar
friskyjake
friskyjake is offline
95 7.3 p.s. check oil level in the morning thur the little hole &it is down 3 inches from the top. truck starts rite aways. just wondering is there a check ball & spring or valve that is not doing it,s job. friskyjake
Old 02-18-2011, 06:31 PM
RRranch's Avatar
RRranch
RRranch is offline
If it's starting fine then there isn't a problem. Why did you check it? depending if yours is the 94 or 97 system the valve could be in different places. 94 is in the HPOP. 97 is in the timing cover. Really it's fine if it starts though.
Old 02-19-2011, 04:09 PM
friskyjake's Avatar
friskyjake
the truck is a 1995, we put in new alliant ac injectors new bosch hpop new ipr valve & new uvc gaskets. after start up & a good hard run of 40 miles i let it sit overnite & checked next morning found oil leak in valley. removed everything again cleaned up & used a ford gasket this time. drove truck hard again let truck sit overnite again. no external leak but resivior is still down. wondering where does the oil go? so where is the check valve in this engine thank you for your reply R R ranch friskyjake
Old 02-19-2011, 04:33 PM
RRranch's Avatar
RRranch
RRranch is offline
95 had 2 different hpop's. The wrong one will certainly cause a low oil level. The 94 pump has the check valve built into the pump. The 96 and up check valve is in the timing cover. It's real important to use the right one. If you don't have a check valve now then that could be the problem. You can quickly ID a 94 motor by the fill plug on top of the HPOP reservoir. 94 has a pipe threaded plug. 96 and up has an o ring seal straight thread plug, usually it takes an allen wrench also on the 96 and up.
Old 02-19-2011, 04:50 PM
Action4478's Avatar
Action4478
Action4478 is offline
I have never heard that one ...TO OP , you may have nicked an O ring on install .. With the covers off , you should see oil bubbling up from the base of an injector if the O ring is bad
Here are 2 pics if the check valve ...Name:  HPOP check valve.jpg
Old 02-19-2011, 04:52 PM
Action4478's Avatar
Action4478
Is it possible you are thinking of the de ariation valve ?
Old 02-19-2011, 05:01 PM
RRranch's Avatar
RRranch
RRranch is offline
I don't think 94 models have those but I could be wrong. I know I'm correct about the check valve though. Or anti drain back valve. 94 style is in the hpop. 96 is in the timing cover. The pumps are interchangeable other than that.
This thread shows the 94 valve location. https://www.ford-trucks.com/forums/6...drainback.html
Old 02-19-2011, 05:12 PM
Action4478's Avatar
Action4478
I'm not convinced ....THat thread was about modding for a different pump ...
Old 02-19-2011, 05:16 PM
Action4478's Avatar
Action4478
Got a pic of the 96 in the cover ?...
Old 02-19-2011, 05:24 PM
RRranch's Avatar
RRranch
RRranch is offline
The valve in that pic on the front of the engine block is the short circuit valve. It lets oil pressure go to the HPOP reservoir on start ups. That's it. The 96 and up front cover was completely redesigned to incorporate the standpipe and the necessary plumbing to keep oil in there when it's shut off. 94 type engines only rely on the check valve built into the HPOP. That's why people only have trouble with it on 94 and 95 models. If you have drainback problems on a newer ones then you really messed something up.
Action4478's Avatar
Action4478
According to this , you are right on the earlier pumps
High Pressure Oil Pump The high pressure pump has had the drain check valve deleted. This brings the variation of high pressure pumps used on the DIT to three. The pumps may be identified by the absence or presence of the anti-drain check valve.
* On 1994 1/2 and 1995 model year engines up to serial number 187099, the initial high pressure pump did have a drain check valve but did not have an edge filter. The edge filter was part of the injection pressure regulator.
* On 1995 model year engines starting with serial number 187100, up to serial number 201680, the high pressure pump did have a drain check valve and an integral edge filter. The edge filter was deleted from the injection pressure regulator.
* On 1996 model year engines starting with serial number 201681, the high pressure pump does not have a drain check valve but continues to have an integral edge filter.
Still don't think there was ever one in the front cover ...
Old 02-19-2011, 05:25 PM
RRranch's Avatar
RRranch
RRranch is offline
It's not an actual valve on the cover. It has been redesigned with the standpipe and different plumbing deleting the valve on the pump. So you can not use a 96 and newer pump on a 95 and older truck without modifying it.
friskyjake
06-27-2017 06:47 PM
friskyjake
03-29-2017 08:15 AM
friskyjake
03-27-2017 10:59 PM
friskyjake
03-20-2017 02:21 PM
friskyjake
01-06-2016 10:43 AM
Quick Reply: low oil level in resivior
