Sponsored by: Real Truck
ABS light on and odometer not working
Old Jan 29, 2011 | 08:19 AM
firebc31a's Avatar
firebc31a
The alternator went out on my 2005 F250 4X4 6.0 the other day. Had that repaired but now the ABS light is on and the odometer is not working. I disconected the batteries to see if thing would reset but no luck. Anyone have any thoughts or ideas?
Old Jan 29, 2011 | 08:45 AM
FoxNotch's Avatar
FoxNotch
could be the speed sensor that mounts on the rear end.
Search that problem a bit and I bet you'll see symptoms similar to yours.
Old Jan 29, 2011 | 11:02 AM
firebc31a's Avatar
firebc31a
Thanks I did see that and did check the conection but figured because of both ABS and odometer are at the same time and started when the batteries went dead because of the bad alternator there may be another problem.
Old Jan 29, 2011 | 11:53 AM
ganzey's Avatar
ganzey
does your speedo work? or turn signals? if they dont its probably a fuse. went out on me and i lost speedo, abs light came on, and no turn signals...
Old Jan 29, 2011 | 04:57 PM
c125bob's Avatar
c125bob
Remove the VSS sensor from the pumpkin and clean it off. It may have gunk and small metal shavings on it. Some are lucky and that solves the problem, some have to replace the sensor. From what you are saying I'd bet that is your problem. Not an expensive fix if you have to buy a VSS sensor. Good luck.
Old Jan 29, 2011 | 06:48 PM
firebc31a's Avatar
firebc31a
I think the turn singals are working but will check. I had checked the fueses the other day but will check again. Thanks for all the input. I will take the sensor out tomorrow.
Old Jan 30, 2011 | 07:17 PM
c125bob's Avatar
c125bob
OK............. how'd it go?
Old Feb 4, 2011 | 11:35 AM
firebc31a's Avatar
firebc31a
All is well
I checked the VSS on the rearend and it looked good. It was hard to tell what the resistence was but it had some. I took the truck to the mechanic that repaired the heads. He ran a diagnostic test and the sensor was coming up bad. but after he cleared out all the codes everything went back to normal. Happer than a pig in slop!!!!!! Thanks
Jude Hosey
Feb 2, 2017 08:12 AM
KaiserKlauss
Jun 16, 2015 06:02 PM
Kaizer88
1983 - 2012 Ranger & B-Series
Jul 13, 2012 12:58 PM
k4uwc
Sep 28, 2009 07:58 PM
cassenbl
Sep 1, 2008 06:06 PM
