Sponsored by: Real Truck
No Speedometer, No Odometer, OD flashing, abs light on
Old Feb 1, 2017 | 10:58 PM
Jude Hosey's Avatar
Jude Hosey
Exclamation No Speedometer, No Odometer, OD flashing, abs light on
So on to the next problem I need some help with on the project truck. 1999 f-250 7.3 diesel. Speedometer doesn't work and neither does the odometer, the ABS light stays on and once you start driving the OD light starts flashing and the truck starts shifting weird. I've changed the rear ABS/VSS sensor on the diff and the OSS on top of the transmission at the tail end. Still no luck, anyone else have any ideas? Any help would be appreciated
Old Feb 2, 2017 | 01:30 AM
Mike189677's Avatar
Mike189677
You need to read the codes I get why you replaced what you did but with out the codes your just hoping you get lucky you need all the transmission codes abs codes and engine codes. I wouldn't rule out wiring issue with that much going on you can replace every sensor on the truck but if the wiring is cut or shorted it won't do you any good. Also wouldn't hurt to go through and make sure all fuses are good even if just for piece of mind.
Old Feb 2, 2017 | 02:27 AM
Jude Hosey's Avatar
Jude Hosey
No check engine light on and I've checked with my code reader just in case. Granted it isn't a great reader.
Old Feb 2, 2017 | 05:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
My first guess would be some sort of VSS error. Hard to say without reading the codes.
If your OD light is flashing, your transmission is telling you that it has error codes.
Old Feb 2, 2017 | 07:51 AM
Jude Hosey's Avatar
Jude Hosey
So I guess my question is is it possible my transmission has a code that won't cause the CEL light to come on and that my reader won't pick up?
Old Feb 2, 2017 | 08:12 AM
Ron94150's Avatar
Ron94150
Yes. Cheap scanners will not read transmission codes. Neither can the parts stores.
agg_bagg
Mar 6, 2019 06:09 PM
Jager
Nov 15, 2010 03:29 PM
ameinig
Jun 14, 2010 10:38 PM
paul 123
1978 - 1996 Big Bronco
Dec 22, 2003 08:28 PM
creede
May 14, 2001 10:33 AM
