Heater problem
Old Jan 16, 2011 | 01:53 PM
JOHN2001's Avatar
JOHN2001
Heater problem
My heat works. I can not change the the settings on my vents it only blows out of the defrost. I need to know for sure what the problem is before i spend money on the wrong part. Thanks in advance
Old Jan 16, 2011 | 02:19 PM
firemaster's Avatar
firemaster
Check for leaks on the vacuum lines under the hood. Either the vacuum box is leaking or the hoses going the hubs.
Old Jan 16, 2011 | 02:30 PM
big poppa's Avatar
big poppa
Firemaster hit it right on. When you start the truck, if theres a leak, you should hear that little compressor turning on and running on the passenger side near the air reservoir. Another place to look is behind your glove box, theres a bunch of vaccum hoses back there that plug into a do dad thingy that diverts air to the selected area components, blend door, exct.
Old Jan 16, 2011 | 03:00 PM
zx250's Avatar
zx250
Of the next Riffraff East
Unless you are running in 4wd, the leak will be at or before the ESOF soleniod.
Old Jan 16, 2011 | 03:06 PM
PaysonPSD's Avatar
PaysonPSD
If you have a 4x4 with ESOF the most likely cause is a vac leak in the vacuum system that locks the hubs.
For a quick diagnosis pull the vac line from each hub and plug each vac line. If the HVAC no longer defaults
to defrost one of the hubs has a leak.
Let us know the outcome and we can go from there.
Old Jan 16, 2011 | 03:09 PM
zx250's Avatar
zx250
Robin is right, but unless you are in 4wd, there will be no vacuum on those lines.
Old Jan 16, 2011 | 03:17 PM
PaysonPSD's Avatar
PaysonPSD
JOHN2001,
You have recently posted about 4wd not working so I'm bettin' your HVAC problem and 4WD probem are related. Vacuum leak.
See this thread. LINK
Old Jan 16, 2011 | 03:26 PM
zx250's Avatar
zx250
If you are having problems while both in and out of 4wd, the I would start by looking at the ESOF solenoid.
Old Jan 16, 2011 | 03:46 PM
F250_'s Avatar
F250_
I have a 2wd truck and the exact same problem... most likely behind the glove box for my situation??
Old Jan 16, 2011 | 03:51 PM
JOHN2001's Avatar
JOHN2001
Can you guys elaberate on the ESOF. I just checked the vacuume lines on the hubs, plugged them like you said and still nothing but defrost. I checked all the hoses behind the glove box everything is on and tight and i checked all the lines on PaysonPSD link under the hood, nothing seems to be wrong, anything else?
Old Jan 16, 2011 | 03:58 PM
zx250's Avatar
zx250
First, make sure you vacuum pump is running. if you are staying on defrost and if you have a bad line, you pump will be running. ESOF, electronic shift on the fly, it's the solenoid beside the vacuum pump. If the pump is running, unplug the line running to the solenoid and plug it. if the pump stops, there's your problem.
Old Jan 16, 2011 | 04:08 PM
PaysonPSD's Avatar
PaysonPSD
If the vac pump isn't running check fuse 28 under the dash.
Another posibilty is a leak in the reservoir.
Open PDF for some ESOF operation info.
File Type: pdf
Old Jan 16, 2011 | 04:13 PM
damicofuel's Avatar
damicofuel
vac pump probably bad. Goes into defrost as a default mode when not working. Pumps are around 100 bucks.
Old Jan 16, 2011 | 04:20 PM
JOHN2001's Avatar
JOHN2001
The compressor works i can hear it when turn the key over, it doesnt shut off, is is supposed to?
Old Jan 16, 2011 | 04:24 PM
zx250's Avatar
zx250
If it's running more than about 15 seconds or so, the yes you have a leak. Start at the vacuum and unplug lines, one at a time and seal opening and see which one causes it to stop. Might be close by and might still be under the dash. As mentioned, it could be the reservoir as well. Start by plugging all the lines at the pump and if it continues to run, bad pump...
