Heater problem
Old Jan 17, 2011 | 05:23 PM
  #31
zx250's Avatar
zx250
Of the next Riffraff East
If playing with the switch will cause the dash light to come on, the I think you found part of your problem. The hubs locking could be a vacuum leak or bad hubs. Might be time to pull the switch and have a good luck at it.
Old Jan 17, 2011 | 05:26 PM
  #32
JOHN2001's Avatar
JOHN2001
Now that i think about it it always goes into 4L with or with out them locked, i can hear the distinctive TINK and its in but 4H not so lucky
Old Jan 17, 2011 | 05:36 PM
  #33
zx250's Avatar
zx250
You got a switch problem I think.
Old Jan 17, 2011 | 05:39 PM
  #34
zx250's Avatar
zx250
And a vacuum leak. lol
Old Jan 17, 2011 | 06:36 PM
  #35
JOHN2001's Avatar
JOHN2001
Figures... Trucks cost me A LOT of money, why not spend a little more. I will hopefully find the vacuum leak tomorrow, and what is the name of the switch that i need (still learning bear with me)
Old Jan 17, 2011 | 06:40 PM
  #36
zx250's Avatar
zx250
ESOF dash switch. Might want to look at it, could just be a loose wire on the back or something simple. And no problem, I didn't know anything when I showed up and still don't know much. lol
Old Jan 17, 2011 | 06:56 PM
  #37
JOHN2001's Avatar
JOHN2001
You know enough to help ,thats all that matters, thanks
Old Jan 17, 2011 | 06:58 PM
  #38
zx250's Avatar
zx250
You're welcome, just hope we get you fixed up.
Old Jan 18, 2011 | 09:24 AM
  #39
JOHN2001's Avatar
JOHN2001
I just disconnected all the lines nothing would make the pump shut off other than the previous mentioned... my luck. Do you guys think it could be my reserivor? If so how can i check it?
Old Jan 18, 2011 | 09:49 AM
  #40
strokingbeast's Avatar
strokingbeast
i guess i need to check all my vac. lines too. My pump stays on but the heater blows out the vents after a few seconds on defrost
Old Jan 20, 2011 | 06:28 PM
  #41
JOHN2001's Avatar
JOHN2001
Is there a place that it could have come disconnected running up to the glove box? And do you think it could be the reserivor?
Old Jan 20, 2011 | 06:37 PM
  #42
zx250's Avatar
zx250
If pulling and plugging the lines that runs out of the reservoir will not cause the pump to stop, then it's a crack in the resy, If it does stop, it's between there and the HVAC controls. You can access some of the lines under the glove box.
Old Jan 20, 2011 | 06:41 PM
  #43
JOHN2001's Avatar
JOHN2001
Reservoir, it is great... thanks again
Old Jan 20, 2011 | 06:53 PM
  #44
zx250's Avatar
zx250
Look it over, might see the crack and seal it with JB weld or something similar. You might can unhook all the lines and plug it, pressurize with air and feel or hear the leak. Oh yeah, if you are in a pinch, you can bypass it for a short time, just cycles your pump a lot, but will work.
Old Jan 21, 2011 | 08:37 PM
  #45
JOHN2001's Avatar
JOHN2001
Today i was driving arond and i had my switch set on floor/defrost and the heat worked fine, when i noticed it i tried to change the settings and they changed for a few mins. and then it went right back to the defrost and is stuck there again, ive checked everything 5X, im "almost" at the point i dont care any more. Any other ideas could it be my switch?
