Heater problem
Old Jan 16, 2011 | 04:24 PM
F250_'s Avatar
F250_
I'll try one more time... does it make sense that my situation (2wd vehicle with no 4wd ESOF equipment), that I would most likely find the problem behind the glove box?
Old Jan 16, 2011 | 04:26 PM
JOHN2001's Avatar
JOHN2001
Alright that settles it, thanks fellas, ill let you know what the turn out is
Old Jan 16, 2011 | 04:27 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yes Pete, it does, but it also can be anywhere from the pump, reservoir, lines to and from and behind the dash.
Old Jan 16, 2011 | 04:30 PM
PaysonPSD's Avatar
PaysonPSD
The only thing you won't have underhood is the PHVS and related hub vac line.
Behind the glove box you will see a vacuum pot with a rod running vertically down below it. That rod moves the blend door.
Try selecting different venting options and see if rod moves.
Old Jan 16, 2011 | 04:43 PM
F250_'s Avatar
F250_
Thanks, guys. I guess I have to chase this dodwn, but I'm going to start at the lines I put in with the Ranger heater valve mod... seems to be the most likely places where my problem might exist. I know that the vacuum pump is kicking on because that's always my signal to take off whenever I start the engine cold.
Old Jan 16, 2011 | 05:08 PM
JOHN2001's Avatar
JOHN2001
i disconnected the line running from my pump to the reservoir and the pump stopped and would turn on for half a second every two seconds, so it is my ESOF?
Old Jan 16, 2011 | 05:11 PM
zx250's Avatar
zx250
Sounds like you have more than one leak or a bad pump. Unplug the line going to the soleniod right beside the pump and do the same and see what happens. Might try both at the same time and see what happens.
Old Jan 16, 2011 | 05:25 PM
JOHN2001's Avatar
JOHN2001
Tried that too the only line that makes it stop is the one running from the reservoir to the pump. It would turn back on because of a bad seal around my finger, lol.
Old Jan 16, 2011 | 05:29 PM
zx250's Avatar
zx250
Ok, plug it back up and move to the line coming out of the resy and see if you get the same results, if so, move on down to the next fitting and so on.
Old Jan 16, 2011 | 05:47 PM
JOHN2001's Avatar
JOHN2001
I did just this and still the same out come
Old Jan 16, 2011 | 05:52 PM
zx250's Avatar
zx250
So, when you plugged the line coming out of the resi, the pump stopped running? if so, the leak is further down line. follow lines to next junction and check there.
Old Jan 16, 2011 | 07:02 PM
JOHN2001's Avatar
JOHN2001
I disconnected the short line off the vacuum pump running to the reservoir on the pump side and pluged it with my finger and it stopped. I went down further and no luck, i will try tomorrow when there is more light outside, thanks
Old Jan 17, 2011 | 03:19 PM
  #28
DJMORETON's Avatar
DJMORETON
I have an 07 6 litre diesel, had the same problem, not completely fixed but you should have constant vacuum going to the heater and pulse vac to the hubs for 4 wd. does your 4wd work ?
Old Jan 17, 2011 | 04:34 PM
  #29
DJMORETON's Avatar
DJMORETON
Old Jan 17, 2011 | 05:19 PM
  #30
JOHN2001's Avatar
JOHN2001
Yes my 4WD does work, not all of the time some times i have to play with the switch and it only goes in for sure every time when the hubs are locked and not on auto. I was hoping to resolve this problem tonight but i forgot my wife has to work and she took the truck, she thinks its hers, and sticks me with a turd of a car (Caliber).
