no start need help
Old Jan 21, 2011 | 06:35 AM
  #61
evans213's Avatar
evans213
I dnt really know but I'm just throughing something out there.... I wonder if it could be the syllonid(I know that's not spelled right but u understand)
Old Jan 21, 2011 | 06:37 AM
  #62
Muktown's Avatar
Muktown
Are any of you guys thinking it might be battery cables? We chased a starting problem on my superduty new batteries starter alternator and it turned out to be the battery cables. They looked ok but corrosion got in behind the insulation. Have you checked voltage at the starter while cranking? The problem is cables are epensive unless you make your own out of welding cables.
Old Jan 21, 2011 | 06:42 AM
  #63
mq1shooter's Avatar
mq1shooter
Is there any switches ( neutral) on a 5 speed that could be causing this? Could this be electrical in the Clutch/Tranny area?...just throwing that out there....
Old Jan 21, 2011 | 06:43 AM
  #64
427 fordman's Avatar
427 fordman
Never thought of batt cables, be worth it to hook up temporary cables to try..
I need to make new ones for my truck as they are getting bad, plus batteries are moving..
Sylenoid should be more of a click than still trying to turn over.
The picture I get in my head is it turns over real slow, like dead batteries. That what you guys get out of this?
Old Jan 21, 2011 | 06:49 AM
  #65
mq1shooter's Avatar
mq1shooter
Say's Brand New Batteries
Originally Posted by pavementpounder96
no i bought this truck for cheap thinking it would be a pretty simple fix and i would have a cheap tow rig for my rock crawlers. so found this one, the guy said it had a fuel leak and needed a starter. he was parking it on a hill and rolling to get it started not sure how long he did it for but. i heard it run, watched him do it and drove it home 20 miles or so figured easy fix right. well i fixed the fuel leak easy enough and put in a new starter. along with everything else is stated above (glow plug, glow plug relay batteries, oil, but have never got it to run since. (about 2 months)
brand new batteries
I've read, and re-read this post...trying to find something obvious.....
Old Jan 21, 2011 | 06:53 AM
  #66
427 fordman
I remember he said new batteries shooter, I was just saying that is the picture I have in my head as to the way it is acting.
Old Jan 21, 2011 | 06:54 AM
  #67
Muktown's Avatar
Muktown
That's exactly what mine did. New batteries wouldn't spin fast enough new starter no change put in new cables fired right up. Would it be possible to hook a jumper cable to the battery and to the starter or relay?
Old Jan 21, 2011 | 06:57 AM
  #68
427 fordman
I'd try to rig something up on the passenger side battery, not worrying about the other one. If one new one with known good cables is hooked it should tell us if that is the problem. Good thinkin on checking the batt cables Justin.
Old Jan 21, 2011 | 06:58 AM
  #69
mq1shooter's Avatar
mq1shooter
True...thats a possibility, that the Battery cables are corroded within the insulation....That huge OEM connector was so corroded / gone, on mine I made a new harness for both batteries from welding cable also...
Old Jan 21, 2011 | 07:05 AM
  #70
mq1shooter's Avatar
mq1shooter
being this is a 5-speed, and I have and auto....is there anything in the clutch / tranny area, like a switch that could cause this?....just throwing this out there...
Old Jan 22, 2011 | 04:31 PM
  #71
DRRXR's Avatar
DRRXR
Arrow Switch
You may have something there
This is a 97 F-150.
Old Jan 23, 2011 | 10:21 AM
  #72
mq1shooter's Avatar
mq1shooter
Thanks for the nice pic Rocky...I just can't get my head around this why the engine will fire by Jump/Pull starting and nothing with a new starter.....
Old Jan 26, 2011 | 04:30 PM
  #73
MONAVIERONJON's Avatar
MONAVIERONJON
looks identical to my 97 5 speed,just jump two wires for the neutral safety switch and that bypasses the system.Also see if there are good battery ground cables from the engine, a simple fix.
Old Jan 26, 2011 | 04:46 PM
  #74
mq1shooter's Avatar
mq1shooter
Been almost a week...wonder if anything has changed?
Old Jan 26, 2011 | 04:50 PM
  #75
MONAVIERONJON
The consensus here is to get the DP gear drive starter,uses almost half the amps the factory does.And these days as most auto parts are made new in china or japan and cheap quality.The DP starters are the same although the design is much better and more simple.
Bowebble
34
Aug 14, 2015 06:34 PM
JoeSwing78
34
Aug 23, 2013 05:53 PM
D4wheeler3
Nov 30, 2012 09:35 PM
02X72
Nov 5, 2010 04:54 AM
dougbrown
15
Mar 30, 2010 08:48 PM
