no start need help
Old Jan 14, 2011 | 11:45 AM
  #31
pavementpounder96's Avatar
pavementpounder96
any thoughts?
Old Jan 14, 2011 | 12:09 PM
  #32
Action4478's Avatar
Action4478
Originally Posted by pavementpounder96
any thoughts?
The IPR is not cheap. You may want to pull it out ,take it apart & clean it before buying one . It could also be the PCM ,& or the IDM too . We are going to need to have you do some testing . Do you have a test light & DVOM ?
Old Jan 14, 2011 | 12:37 PM
  #33
pavementpounder96
No i do not have either of those i can ask my brother he might
Old Jan 14, 2011 | 01:03 PM
  #34
DRRXR's Avatar
DRRXR
Like Rick said
IPR Valve
$174 + shipping (specify year)
http://www.rosewooddieselshop.com/store/7.3oem.htm
Rosewood Diesel Shop
Old Jan 14, 2011 | 01:23 PM
  #35
Action4478's Avatar
Action4478
I hate to recommend anyone buy parts to try to repair a non running truck . Having a spare IPR is not a bad thing. Buying it to fix a problem & then having it be something else is a waste of money ..There are a few tests that can be done to narrow it down. most of them are cheap , before I will tell you to buy something . By the way ,do you have a spare CPS ?
Old Jan 14, 2011 | 01:34 PM
  #36
pavementpounder96
ok i have a test light and dvom
Old Jan 14, 2011 | 01:35 PM
  #37
pavementpounder96
nope no spare parts but my buddy has a 97 psd i could maybe borrow some parts.
Old Jan 14, 2011 | 01:41 PM
  #38
Action4478's Avatar
Action4478
The CPS is known to cause a crapload of different symptoms . May want to get one from Ford (about 25.00) & try it too . you will need a spare .
If you have a test light , On the passenger side of the fuel bowl ,there is a main harness plug for all the 12V items . Unplug it ifyou need to ,to test for 12v there ,with the key on. Or you can test for voltage right at the IPR itself . If you test at the IPR ,be careful.
Old Jan 14, 2011 | 01:48 PM
  #39
Action4478's Avatar
Action4478
Cool ...
We may want to test your PCM & IDM in his truck
Old Jan 14, 2011 | 01:52 PM
  #40
pavementpounder96
OK i will call him and ask him to bring his rig over. if the pcm and idm were not working would you still be able to "pull start it" when i got it the guy had been doing that to get it started and thats how i drove it home.
Old Jan 14, 2011 | 02:01 PM
  #41
Action4478's Avatar
Action4478
No pull start with a bad PCM or IDM .
Your problem started after you did the starter right ?
Old Jan 14, 2011 | 02:05 PM
  #42
Action4478's Avatar
Action4478
How old are the batteries & have you tested them ?..
Old Jan 14, 2011 | 02:08 PM
  #43
pavementpounder96
no i bought this truck for cheap thinking it would be a pretty simple fix and i would have a cheap tow rig for my rock crawlers. so found this one, the guy said it had a fuel leak and needed a starter. he was parking it on a hill and rolling to get it started not sure how long he did it for but. i heard it run, watched him do it and drove it home 20 miles or so figured easy fix right. well i fixed the fuel leak easy enough and put in a new starter. along with everything else is stated above (glow plug, glow plug relay batteries, oil, but have never got it to run since. (about 2 months)
brand new batteries
Old Jan 14, 2011 | 02:12 PM
  #44
Action4478's Avatar
Action4478
starter (glow plug, glow plug relay batteries, oil,
did you do all of these things at the same time or did it run after the starter replacement?
Old Jan 14, 2011 | 02:15 PM
  #45
pavementpounder96
all at the sametime. it has never ran since i parked it after it was pull started
