Oh BOy Lighting Problems
Old Jan 14, 2011 | 01:08 PM
  #31
lexustbs's Avatar
lexustbs
Originally Posted by rdenis
Also I am sorting throught the mic connection. Something is not quite right with the connection instructions - I suspect they may be specific to non nav systems.
I added nav after the fact. This is where all my problems started.
Old Jan 14, 2011 | 02:07 PM
  #32
rdenis's Avatar
rdenis
Okay time to start ruling in/out some causes.
Is the mic still connected? If it is can you disconnect it and then see if you get any of your funcionality back.
Old Jan 14, 2011 | 02:14 PM
  #33
lexustbs's Avatar
lexustbs
Ill have to do this tonight, but if I rememebr correctly, I had it undone last night and still had this issue. But i'm not 100% on that. Do you have any hunches? Is there a way to reset the BCM or something?
Old Jan 14, 2011 | 02:19 PM
  #34
lexustbs's Avatar
lexustbs
ok update, just went out and just cut the wires off in the glovebox to terminate the connection, but where i could solder them back easilty. Still no joy on the lights
Old Jan 14, 2011 | 02:26 PM
  #35
rdenis's Avatar
rdenis
No worries, that is good as it rules out a short if in fact the instructions are incorrect - now I want to get the ACM to trigger a couple of DTC's.
Okay here we go:
1) Start the truck.
2) Turn on parking lights.
3) Enter diagnostics mode on the nav screen by holding down 3 and 6 on the radio.
4) Exit the annoying speaker test.
5) Select "View DTC's" and record any codes. Go back to main menu.
6) Select "Configuration Status" and record the code - either a 0 or a 1. Back to main menu.
7) Select "Sensor I/O" Status and record what it says under "Illumination". Go back to main menu.
8) Select "Microphone Test" and report results of test. Return to Main Menu.
9) Select "On Demand Self Test" and report results. (This one might take a bit of time). Return to Main Menu.
10) Check the DTC's once again and record what is reported.
I'll explain the significance of all this once you have got this info. I am pretty sure I've got the diagnosis and solution but these tests will serve to confirm.
Old Jan 14, 2011 | 02:39 PM
  #36
lexustbs's Avatar
lexustbs
Okay here we go:
1) Start the truck.
ok. View DTC Codes: C100101 No Rearview Camera
Config Status:
DSP:0
FES:0
RESEM:0
SDARS Cont:00
AuxJack:0
InternalSDERS:1
Front Speakers Only:0
AUx1:10
Aux2:00
AUx 3:00
Shaker:0
SWC1PodType:11
Brand:001
SWC Pod:11
Convert.:0
RPA:1
Reverse:0
Voice Reg:1
FES Type:0
OccupancyMOde:1
Dolby Internal:0
Climate COntrol:00
Illumination:0
Daytime Stratgey:1
Sensor I/O
Illumination:ON
MIc Test: B1D7901 Microphone not Found
DTC Again: C100101 Rearview Camera, B1D7901 Microphone Not Found
Old Jan 14, 2011 | 02:47 PM
  #37
rdenis's Avatar
rdenis
Did you run step 9 - the On Demand Self Test? Or did it just report the same results as the final DTC check?
Old Jan 14, 2011 | 02:49 PM
  #38
lexustbs's Avatar
lexustbs
That test said nothing was wrong. Sorry
Old Jan 14, 2011 | 03:13 PM
  #39
lexustbs's Avatar
lexustbs
Ok now my trucks interior light is stuck in the night mode. Even if I switch it all to off the truck still stays in nighttime
Old Jan 14, 2011 | 03:15 PM
  #40
rdenis's Avatar
rdenis
Okay good. Just looking at the data for your configuration status, their should be a config code for APIM. Usually it is the third line down right after the FES code on the first screen. Can you double check that again and see if it is there - it may be on a different screen (I think there are about 9 of them within the Config Status reports).
The APIM is your SYNC system and USB plugin.
Old Jan 14, 2011 | 03:20 PM
  #41
rdenis's Avatar
rdenis
Ah ha a further clue - that's a good sign actually nigttime mode is a default mode thrown by the BCM when it detects problems with the interior lighting - I've got to run out for about two hours now but I'll be back.
  #42
lexustbs's Avatar
lexustbs
Apim is set to 1. Never mind on the lights being stuck. Do the power window backlight stay on all the time? Mine do?
Old Jan 14, 2011 | 03:21 PM
  #43
djjoshuad's Avatar
djjoshuad
I'm starting to think rdenis is a ninja...
Old Jan 14, 2011 | 03:29 PM
  #44
lexustbs's Avatar
lexustbs
Disregard the nighttime mode. I just covered my hand over the sensor and it changed. I had just dimmed the panel and forgot to bring it back up. But my power window backlight are still always on?
Old Jan 14, 2011 | 05:58 PM
  #45
lexustbs's Avatar
lexustbs
just to add some more of my own testing. I went and put the old OEM radio back in and tried the lights, nothing. tried the sync, nothing? Is that a good sign for what your thinking? Or is this bad boy goofed up big time? I mean, can the dealer figure this out if you can't? You seem to know everything to do! haha
