1984 Heater Blower Switch
Old Jan 8, 2011 | 09:36 AM
jds84's Avatar
jds84
Hi, I have a 1984 Ford F150, 351 Windsor, dual gas tanks, and factory air conditioning I am having no end of trouble with the heater blower fan. Is it possible to rewire the blower motor to a simple off/on toggle type switch? I really need to get the defrosters to work.
Thank you,
Old Jan 8, 2011 | 09:57 AM
ctubutis's Avatar
ctubutis
You could prolly do that using a 30A (or so) relay, you would have only ON or OFF.
What are the problems you've been having? What troubleshooting have you done and
what have you found?
It's fairly common for AC-equipped trucks to have problems with the temperature blend door
breaking off the hinge and the vacuum motor end up merely pushing a rod up and down
instead of swinging a door open & closed.
Or, some guys disconnect the vacuum reservoir(s) thinking they're making things "better"
and "cleaning up the engine compartment" by removing things *****-nilly without really
knowing what they're doing....
You don't see too much out here about the blower motor itself, though; whatchya got?
Old Jan 8, 2011 | 10:11 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you have power in the dash and no power getting to the blower fan it's more than likely the blower resistor is bad or it has come loose from it's plug.
Old Jan 10, 2011 | 11:53 AM
Holmesuser01's Avatar
Holmesuser01
The blower resistor is under the hood on the blower box. They do go bad.
Old Jan 10, 2011 | 01:08 PM
Franklin2's Avatar
Franklin2
If the resistor assembly goes bad, the blower should still work on high.
Old Jan 10, 2011 | 01:20 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
...Unless the plug is all corroded or loose.
Old Jan 10, 2011 | 01:23 PM
DJMORETON's Avatar
DJMORETON
new to this forum could someone please tell me how to actuall "POST A QUESTION" Thanks
Old Jan 10, 2011 | 01:42 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
In each subforum (you're in the 80-86 forum now) if you go to the index page for whichever one you need, there in the upper left corner, just above the threads list you will see a button for "New Thread"
Click there and try to convey in the thread title what it is you need.
Welcome to the forum DJMORETON
Old Jan 10, 2011 | 05:01 PM
Eddiec1564's Avatar
Eddiec1564
Here's some more info mostly about the blend doors and duct work problems.
https://www.ford-trucks.com/forums/1...cs-needed.html
I'll add to that link with he blower motor wireing diagrams...
Old Jan 10, 2011 | 05:48 PM
Franklin2's Avatar
Franklin2
You can't hardley read this diagram, but if you look close, you will see on high speed the blower gets power directly from the dash speed switch, and doesn't go through the resistor at all.
Old Jan 11, 2011 | 02:11 PM
Eddiec1564's Avatar
Eddiec1564
I am not sure why FTE is resizing the drawings.
I have seen the ground going to the blower motor melt on my truck. Ran wire directly to the battery fixed that for me.
Old Jan 11, 2011 | 07:09 PM
Franklin2's Avatar
Franklin2
Do you have a picture hosting site you use? Put it on there and bring it in, I wouldn't mind having that drawing blown up.
Old Jan 11, 2011 | 09:39 PM
Anafiel's Avatar
Anafiel
Here are all the related images in their full size. Credit goes to eddie for first posting them.
https://www.ford-trucks.com/forums/1...ml#post9764207
WhyFord
1978 - 1996 Big Bronco
Aug 9, 2016 07:35 PM
hotrod351
Jul 29, 2016 12:50 PM
red rider #1
13
Mar 29, 2016 10:38 PM
mkm43057
Sep 19, 2015 11:44 PM
danielcoyle
May 31, 2014 06:46 AM
