2000 E 250 heater issues
Old Mar 29, 2016 | 04:29 AM
red rider #1's Avatar
red rider #1
Hi, i have a 2000 ford E250 that the blower motor blows on high no matter where the fan selector **** is . I have changed the Blower motor switch and pigtail and the resistor and pigtail. Blower motor still runs on high no mater if the selector **** is on low or Med . Still runs on high speed. Don't know where else to check for the problem. Thnx Dave
Old Mar 29, 2016 | 05:20 AM
jimandnena's Avatar
jimandnena
Hi Dave, maybe the MAX A/C setting is causing the problem? I think it runs the blower on full even if the temp is set to hot. jim
Old Mar 29, 2016 | 05:23 AM
red rider #1
Thnx for the reply Jim. Any idea how to check to see if this could be the problem?? Thnx Dave
Old Mar 29, 2016 | 05:36 AM
red rider #1
The heater works great the A/C works good. Vents and defrost to floor all are working. But what ever i do it will not run but on high no matter if i set the fan control to low or any other position. Has ne stumped as what or how to check out the problem. Thnx Dave
Old Mar 29, 2016 | 06:10 AM
jimandnena's Avatar
jimandnena
Almost has to be a wiring short somewhere? Can you ring the switch wires to look for shorts between them and to ground? jim
Old Mar 29, 2016 | 06:28 AM
red rider #1
Jim.. not sure what you mean by ring the switch wires. Thnx Dave
Old Mar 29, 2016 | 09:44 AM
Mitch Eckler's Avatar
Mitch Eckler
Hey All-
Not to cut in front of Jim. His logic line seems really solid, worth looking into.
However, reading through my first thought was the dash selector switch needs to be replaced. It may be a short in the selector itself. A working junkyard component is easy to remove and pretty cheap as far as repair costs go. I hope my suggestion isn't too foreword, but thats right where I'd start.
If the problem persists then I would grab my multi-meter and go-to-town on the harness items leading to the motor.
Old Mar 29, 2016 | 10:10 AM
red rider #1
Thnx for the reply. The selector switch meaning the switch that controls where the air is coming out ( example, vent or floor or defrost). If so isn't that vacuum controlled.. Have changed the fan selector switch and pigtail.. Multimeter is going to be next move.
Old Mar 29, 2016 | 10:15 AM
Mitch Eckler
Correct, but the selector that controls the fan speed is just copper contacts. 16 years of fan speed selection is a lot on those little copper/brass contacts.
The "Hi" selection is also the least used of the lot as well.
-M
Old Mar 29, 2016 | 11:02 AM
red rider #1
Have already changed the fan speed selector and the pigtail. Still any speed on the selector is still high speed
Old Mar 29, 2016 | 11:46 AM
jimandnena's Avatar
jimandnena
Oops, sorry, I meant to ohm out the wiring from the switch to see if the wiring was shorting to ground somewhere. The speed switch completes a ground to the resistor pack and on hi speed, directly to the motor. Power is applied to the motor with a relay as soon as the control is moved out of the OFF position. There are several diagrams here on the site, a search should find one easily. jim
Old Mar 29, 2016 | 12:10 PM
red rider #1
Thnx for the help Jim. I'll see if i can find a diagram on this. Dave
Old Mar 29, 2016 | 12:20 PM
red rider #1
Kinda new at this. Tried to find a diagram on the wiring , but can't seem to find any diagrams. I must be searching in the wrong area. Is there a area that i should look in ?? Thnx dave
Old Mar 29, 2016 | 10:38 PM
jimandnena's Avatar
jimandnena
Plug this line into google and click images:
heater fan diagrams site: ford-trucks.com
You'll have to pick one that matches your setup best. Here's the link I used (if it works?):
https://www.google.com/search?q=heat...ewAb0Q_AUIBygC
jim
jb10
Dec 16, 2008 10:57 PM
billy87
Apr 14, 2004 02:25 AM
dbuck50
Jul 10, 2003 11:22 PM
bansheeboy182
Electrical Systems/Wiring
Oct 16, 2002 10:58 AM
tms217
1983 - 2012 Ranger & B-Series
Jan 5, 2002 12:13 AM
