So my door tag says my axle number is a 35, does that means I have a 4.10 gears in 10.25 without limited slip? The numbers on the axle tag say
S 129 N
4.10 10 2 7C12
I'm just trying to figure out which axle I have thanks.
dont matter because almost all of them are one wheelpeals by now! 164k and a fresh change of oil and friction modifier and its still a pig to get both wheels to hook, even in the snow!!!
LOL... Yes! I hear the frustration in your response!
Yes I'm not happy to hear my rear end is open. It kind of blows me away too cuz this truck seems to have the best of everything else. 97 F350 with Dana 60 7.3 auto. Who wouldn't have ordered a better rear end?! I just off this several months ago so it is my first winter with it and the open rear end doesn't cut it at all. What are my options? Detroit lockers?
In my opinion, if you haul weight in the truck bed, a ton or more, a locker is nothing but a headache and may cost you more money when stuff breaks.
If you haul weight, a limited slip with clutches or a selectable locker like the ARB air locker that you can switch to open when you have a load on.
If you never haul weight in/on the truck, a locker is fine.
I had a locker in my IDI, with a dump bed on it.
I also live in the mountains.
Couple tons of rock in the bed pulling a steep hill, the truck went straight no matter where you turned the front wheels.
Need to turn, hit the clutch to unload the drive line and unlock the axle so it would turn.
On more than one occasion, I scheared off the bolts holding the axle flange to the rear hub.
I don't have quite as much traction when I plow snow, but when I load up a load of stone the Trac Lok with clutches works much better for me.
