rear axle identification
Old Aug 25, 2016 | 04:33 PM
deezdrama's Avatar
deezdrama
Question rear axle identification
Can anyone help me identify my rear axle and gear ratio? The door tag says c2 which only thing I could find is dana 61 but only listed f250 and not my e350.
Rear dif tag numbers dont match the formats of the number identification sites I went to.
First 3 numbers are 4 10 so do I have 4.10s?
Any help is appreciated.
Old Aug 25, 2016 | 05:45 PM
Conanski's Avatar
Conanski
One source I found stated axle code C2 is 4.10 limited slip. The factory axle in these vans is the dana 60 semi or full float. Look for the "60" designation at location 3 in the diagram below.
Old Aug 25, 2016 | 05:54 PM
jimbomitch's Avatar
jimbomitch
That's what I came up with as well: What rear end ratio is in my Ford , do I have positraction? - Drivetrain
Old Aug 25, 2016 | 08:09 PM
fordman75's Avatar
fordman75
Usually if it's a limited slip the tag on the diff would read 4L10 instead of 4.10 . But I'm use to older stuff.
Did your diff have one tag or two? I've also seen some limited slip diffs have a second tag reminding to add the friction modifier to the lube.
Old Aug 25, 2016 | 08:21 PM
Boondockdad's Avatar
Boondockdad
Looks like a 4.10 Trac-loc
Old Aug 25, 2016 | 09:43 PM
deezdrama's Avatar
deezdrama
Thanks for the help guys! Ill have to wait untill I get off work tomorrow and check for casting numbers
Old Aug 25, 2016 | 10:32 PM
VOODOO7.3's Avatar
VOODOO7.3
Your BOM is 606845-6, which is Semi-Float, 4.10 gear ratio, Trac Loc limited slip diff. (unless previous owner changed ring and pinion). The BOM is on the tag as well as stamped into the rear of the right axle tube. About 6 inches to right of the housing. Numbers are about 1/4" high.
Old Aug 27, 2016 | 10:47 AM
deezdrama's Avatar
deezdrama
Thanks guys. My stamped/cast codes dont seem to match up. Where the 60 series stamp is supossed to be it looks like a date stamp, and I have no codes that I could see on the tubes.
Ive attatched pics of the codes I did see.
Im building a general use/ camping rig. Wont see much off road use but maybe some bad gravel/dirt roads so if I have some form of locker that is a plus. Maybe tow a small boat trailer in the future.
Old Aug 27, 2016 | 02:49 PM
VOODOO7.3's Avatar
VOODOO7.3
Every Dana axle has a BOM a few inches to the right of the date code stamp. They can be hard to see through the rust or undercoating, but like I said earlier, it is also on the silver tag. Just remember to add friction modifier if you change rear axle fluid. Cheers!
Old Aug 27, 2016 | 04:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1959 thru today: If the AXLE code stamped on the Rating/Warranty Plate or printed on the Certification Label begins with a letter: Limited Slip.
If the AXLE code begins with a number: No Limited Slip.
Old Sep 1, 2016 | 07:57 PM
deezdrama's Avatar
deezdrama
So whats right?
The BOM saying its LS
or the Lack of the "L" meaning its open diff?
Old Sep 1, 2016 | 08:07 PM
fordman75's Avatar
fordman75
So whats right?
Lack of the "L" does not mean open!
I recently bought a 2000 E350 rear diff. And the axle tag says 4.10 and it's a limited slip rear. At the lower right corner of the tag it does have "LS".
If the BOM says it's a LS it's probably a LS.
And NumberDummy says if the axle code on your door decal starts with a letter, like yours does, then it's a LS.
Old Sep 1, 2016 | 08:16 PM
deezdrama's Avatar
deezdrama
Ok...thanks for clarification
I didnt catch that he was talking about the door sticker lol (ah.... i can be such a layman at times)
grumpyinme.
Jan 9, 2019 09:22 AM
George84
Nov 4, 2010 05:06 AM
classyfish
Aug 8, 2007 04:16 PM
Dave Barbieri
Jan 30, 2005 06:43 AM
rsrxc700
Apr 26, 2003 08:41 PM
