Identifying axle Ratio
C 426 B
10 10 5 2023
Is this an axle code 42 (4.10?)
Edit: thought you had the truck, not just the axle.
The only thing I can tell you is, this axle does not have Limited Slip.
1959 thru today: If the AXLE code begins with a letter: Limited Slip. If with a number: No Limited Slip.
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Or, turn the pinion and count the number of turns to complete one revolution of the rotors/tires/whatever is bolted on.
Since the second line on the tag starts with '10', and there are no 3.10 or 5.10 gears...Its probably safe to say that you have 4.10's.
I looked up the code on my door and discovered it's C3 which as I understand is 4.30
However after doing the vin look up (screen shot attached) it says, if I'm understanding this correctly that I have 3.73 gears. But on the 2nd screen shot it shows several different possibilities.
If my Ex has 3.73s I'm definitely going to have the front and rear regeared. I was comptemplating having her regeared if she had 4.30s to 4.80s
all seeing as how I'm running 315/75R 16 BGF ATS.
I believe she has the 4.30s because at 65mph (using GPS speed tracking) she's right at 2100 RPM in over drive.
ANY incite in this to help me figure out what exactly I'm working with will be greatly appreciated.
Lastly what's the difference and over all benefits of a full floating axel vs. a semi floating axel (if I'm saying that correctly) ?
This is an area I don't have much experience in aside from breaking them in my old '83 Ford F150so 9 inch rear.
https://www.etis.ford.com/vehicleReg...45004.fcvas511
. Much better all round performance too,
should have put the 4.30s behind all the 6.8s.
The VIN decoder is showing the standard gear ratio of 3.73, your 4.30s were the optional choice ( better choice
). The section where you have the "?" Is showing the various ratios of each gear in the 4R100 overdrive transmission. The area that you have the box around shows the 3 axle ratios available in the EX platform, only the V-8s got the 4.10 as far as I know. The spring capacities shown are correct for a V-10, each motor had different front spring capacities based on engine weight but all of the EXs had the same rear springs. The listed axles capacities are incorrect for the front axle, I think the number should be 5600 lbs (I could be little off on the Dana 50 rating, but it's not 9900 as listed) but the rear number looks right.
You helped settle the debate I was waging in my head over this.
I'll definitely be upgrading to 4.80s down the road, especially seeing as how the wife has started hinting around that she'd like to get a travel trailer sometime.
With upgrading the gears to 4.80s, that'll effectively change the cruising speed RPMs of the motor if I'm not mistaken. That'll bring em up to or about 2500 RPM +/- correct?
Reason I ask is for fuel mileage. With my current setup up I'm squeezing out just over 12 mpg. that's with the CC set at 65 (by GPS speed tracking ) and my RPMs just a Lil above 2k.
I'm curious as to how 4.80 gears will affect that while not towing as my Ex is a daily driver.
Again thank you for everything.
The only long distance run I've made in the current configuration without the TT in tow was from home to Savannah GA, along the same route as above basically. With the cruise set at 65 MPH it logged 12.5 MPG on that pure highway run. On the way home I was towing a '94 Geo Metro on a car dolly (my current daily driver
) and got the same mileage at the same speed. For the past three years we have been pulling our 41' 11,000 lb TT between 3 and 6 thousand miles a year and typically see between 8 and 9 MPG on our mostly highway trips with a best yet 9.4 coming home from Niagara Falls over the Summer. The addition of Banks headers and 5Star Tunes has helped to push the economy up some.
When I had swapped in the 4.88 gears I ran 32" tires and using a GPS for the speed and my Ultra-Gauge for the revs I checked the revs at various speeds and then compared them to the revs with the new Nitto 35.28" tires.
Speed...........32" tires..........35" tires
50.................1930...............1720
55.................2075...............1900
60.................2280...............2055
65.................2430...............2230
70.................2595...............2400
Eventually my Ex will becomea dedicated hauser and play rig, until then I'm doing my best to keep her alive and running strong.
Would I be correct in that the rear end is a 10.5 Sterling ?
Who did you go through for your 4.88s?
I'll have to have a mechanic shop do the install for the front and rear as I've heard stories good and bad getting those bad boys in making sure that they don't explode in the case after install. I've heard the tolerances are exacting with differentials.
My 4.88 axles have their own story, I bought them from a guy in WI after they failed to sell in an eBay auction for $1800. He agreed to my $1500 offer and when I told him I was driving out from Philly to pick them up at his dairy farm he laughed and dropped them down to $1200! So my wife and I had a nice weekend driving date and we got a set of axles that were already setup and broken in for our EX.
. But yes, if you have a shop do the gears make sure to find a shop that has a good rep and has done a lot of these axle gear jobs.
