Weird electrical problem
Old Dec 8, 2010 | 09:18 AM
Scratcher's Avatar
Scratcher
This midwest freeze is doing some weird stuff to my truck. Twice now I have started at 7f (minus 10c)with no problems. But my heater blower and turn signals don't work. Then after an hour of running if I turn it off and back on again they start working! This is the second time this has happened in four days.
Old Dec 8, 2010 | 10:50 AM
DieselScoff's Avatar
DieselScoff
First things that come to mind is a reset signal going to the ecu that it is not receiving, can you shut it of after 15 or 20 minutes and start it back up to fix the problem or only after an hour?
Old Dec 8, 2010 | 11:15 AM
farmert's Avatar
farmert
Does the Key switch return to center when you let off of it? It sounds as if the switch is sticky when cold, and not letting it go back to center.
Old Dec 8, 2010 | 11:16 AM
Scratcher's Avatar
Scratcher
Thankfully there is no ECU on an IDI
Old Dec 8, 2010 | 11:19 AM
Scratcher's Avatar
Scratcher
This sounds feasible. LOL its usually the obvious thing that I miss. I will check that in the morning again when shes stone cold.
Old Dec 8, 2010 | 11:21 AM
PLC7.3's Avatar
PLC7.3
Check the fuses first.....#6 30 amp.....heater
Then check the turn signal relay in the fuse box..... could be cold/heat related.
Old Dec 8, 2010 | 11:37 AM
Scratcher's Avatar
Scratcher
Can't see it being fuses related otherwise it wouldn't have started working again
Old Dec 8, 2010 | 03:46 PM
tecgod13's Avatar
tecgod13
I'll second this.
Does the radio or other accessories have the same problems? I've noticed it a few times when the radio didn't come back on after starting (on while waiting for glow plugs, then off during cranking). Wiggle the key and its all good.
fishmanndotcom
Escape & Escape Hybrid
Nov 11, 2020 07:49 AM
78 & 87 Super Cab
Jan 7, 2013 08:50 PM
shurbs2004
May 18, 2007 04:14 PM
FreakinOldGuy
Electrical Systems/Wiring
Mar 3, 2005 06:30 PM
MatthewC
1978 - 1996 Big Bronco
Oct 8, 2004 10:50 AM
