Ok I know I read this somewhere on here and now can't find this in the search engine! So could someone clarify this for me! I believe that the difference between radiator core supports for a 89 IDI one w/ac and one wo/ac is none! Is this correct? No difference between the two? Thanks in advance!
I do believe they are the same, the earlier truck (86 and older) sometimes were different, but the air vs non air trucks should be the same by 89. If you were closer, I could set you up with one...
