Weird electrical issue
Old Jan 7, 2013 | 07:48 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Was driving home this evening from picking up a free topper, when I discovered My turn signals,and brake lights were not working. My taillights were working and the turn signal indicators in the dash were flashing normally when I made turns. Now here is where it gets weird. When I shut the headlights off, I had brake lights,and turn signals again. What the heck is the problem?
Old Jan 7, 2013 | 08:16 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You have a ground issue somewhere.
Check the grounds for the rear lamps by removing both taillights. You will see a eyelit connection screwed to the bed. Make sure they are clean and tight.
You may also have to check the lamp sockets.
The front grounds are located on the inner fenders, just above the side marker lamp lens assymbly.
The Brake and turn signal lamps share their ground with the parking lamps.
With a bad or corroded ground, What is happening is your brake and turn signal lamps are finding ground through the parking lamp circut. When you turn on the headlamps, that eliminates the ground and the brake and turn signal lamps no longer function.
Old Jan 7, 2013 | 08:49 PM
Gary Lewis's Avatar
Gary Lewis
Amen! And, I'd rep you for that but am still in rep purgatory. Not only did you tell him what the problem is, but where to look.
Old Jan 7, 2013 | 08:50 PM
78 & 87 Super Cab
Ok thanks, I will check the right front one first,, as it does not work with the lights on, but will go ahead and clean them both
rworld
Apr 25, 2025 01:15 PM
RICHMC54
Sep 15, 2016 05:06 AM
snipa
Jul 3, 2005 08:01 PM
ranger429
Aug 26, 2003 03:39 PM
lilpig88
Electrical Systems/Wiring
Jan 24, 2003 07:49 AM
