front end jumping in a turn.
Old Dec 3, 2010 | 10:41 AM
Country_boy_2007's Avatar
Country_boy_2007
ok i got a D60 in my f250. when the hubs are locked in, weather its in 4 or 2 wheel drive, if you make a tightish turn it feals like the axle shafts are binding in the front axle and the front end kinda jumps. any suggestions? is it just the u joint yokes binding in the turn? or some other problem
Old Dec 3, 2010 | 10:44 AM
snaponprofile's Avatar
snaponprofile
Mine does that in 4x4, It could be stuck in 4x4.
Old Dec 3, 2010 | 10:58 AM
ramseygus's Avatar
ramseygus
unlock your hubs and it should stop.
Old Dec 3, 2010 | 11:43 AM
rodneywar's Avatar
rodneywar
mine binds a bit when i am at full lock i would say its normal
Old Dec 3, 2010 | 11:59 AM
thomabb's Avatar
thomabb
Normal bind. In a turn the outside tire is rolling faster than the inside one. Tighter the turn, the greater the delta.
Old Dec 3, 2010 | 04:38 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
in 2wd it shouldn't be doing this though.
check the locking hub assembly to insure they are disengaging.
Old Dec 3, 2010 | 05:37 PM
rodneywar's Avatar
rodneywar
it dont matter cause he was locked in and turning wether the xfercase is enaged or not it will bind a bit
Old Dec 3, 2010 | 11:39 PM
Country_boy_2007
ok sounds like a normal deal, i was wondering because my 87 chevy 1 ton with a 60 front dosent do it.must just be a ford thing.
Old Dec 4, 2010 | 10:12 AM
Ford_Six's Avatar
Ford_Six
It's much more noticeable if the front diff is any kind of locker or limited slip. Check the universal joints too, though. If there's any rust around the seals, they are on their way out and should be replaced. If they come apart on their own, typically you will need new axle shafts too.
Old Dec 4, 2010 | 04:52 PM
Ford F834's Avatar
Ford F834
When I first got my F350 with Dana 60 front axle I thought the same thing.... that something was wrong with it. Couldn't make a turn in 4WD. They definitely have an aggressive limit to the amount of slip in those axles. (At least in my example, and apparently yours too). My 81 F250 with TTB will bind and jump a little, but only on very hard surface at full turn. The Dana 60 is an awesome axle, and the 4x4 capabilities continue to amaze me, even after I think I've seen it all. The binding is a bit annoying if you are driving on alternating soft then hard surfaces and needing to make tight turns, but the benefits are tremendous. Way more jumping than most 4x4 trucks, but way less slipping and digging yourself into a mud and snow rut when it really counts
Old Dec 4, 2010 | 08:40 PM
Country_boy_2007
yea the 50 ttb would jump a little at lock, this just jumps a little more. i was just makeing sure i dont have a problem. i love the dana 60 though. its a tough axle. only thing i dont care for is pullin the carrier out of it and shimming the carrier. its a pita to do
mikepo
28
May 23, 2016 01:07 AM
KeysMako192
6.7L Power Stroke Diesel
54
Jan 27, 2016 07:15 PM
Ruffinit
1983 - 2012 Ranger & B-Series
Jan 24, 2012 10:02 AM
dvw70
Jan 4, 2011 01:56 AM
suzukijoe
Feb 9, 2006 08:38 PM
