Swagger : Build Thread
Old Feb 7, 2011 | 10:15 AM
  #286
rat49f6's Avatar
rat49f6
Correct they will hard to be redrilled
Old Feb 8, 2011 | 02:59 PM
  #287
rat49f6's Avatar
rat49f6
ok guys i need everyones opinion
which switch box color???
AVS :: AVS Switchboxes :: ARC-9 SERIES :: GREEN 9-SWITCH SERIES (ROCKER)
or
AVS :: AVS Switchboxes :: ARC-9 SERIES :: BLACK 9-SWITCH SERIES (ROCKER)
Old Feb 8, 2011 | 03:02 PM
  #288
gbroehl1's Avatar
gbroehl1
If the green doesn't match your existing green close enough then I would say go with the black.
Old Feb 8, 2011 | 03:03 PM
  #289
bama29fan's Avatar
bama29fan
Are you going to keep the Kawasaki Green scheme? what are you ultimate plans for interior color? i firgured of all people you would automatically be drawn to the green
Old Feb 8, 2011 | 03:25 PM
  #290
rat49f6's Avatar
rat49f6
i have no way of knowing how close the green is other than it is described as "antifreeze green"
the interior will be black with kawi green inserts in the seats
Old Feb 8, 2011 | 03:37 PM
  #291
gbroehl1's Avatar
gbroehl1
I would lean toward the black then.
Old Feb 8, 2011 | 03:43 PM
  #292
bama29fan's Avatar
bama29fan
Yeah...go with black and if you feel inclined you can always paint in to be an exact match latter.
Old Feb 8, 2011 | 04:03 PM
  #293
farmb0y's Avatar
farmb0y
Get the black, then pull the cover off and poweder coat it your kawasaki green!!!
Old Feb 8, 2011 | 04:42 PM
  #294
rat49f6's Avatar
rat49f6
pretty sure the cover is plastic but the gf says i should get this on for a mear $70 more
AVS :: AVS Switchboxes :: ARC-9 SERIES :: BILLET BRASS KNUCKLE 9-SWITCH SERIES (ROCKER)
that one is billet aluminum so i can powdercoat it
Old Feb 8, 2011 | 04:47 PM
  #295
gbroehl1's Avatar
gbroehl1
Spend the extra 30 for the billet if you want (I still think black is more your truck's thing), but save the 40 more and loose the brass knuckle look.
Old Feb 8, 2011 | 05:42 PM
  #296
High Intentions's Avatar
High Intentions
Mod Specialist ;)
Get the billet and power coat it.
Old Feb 8, 2011 | 05:52 PM
  #297
Nice Work Truck's Avatar
Nice Work Truck
I like the billet Jim.
Then you can do what you want to down the road.
Old Feb 8, 2011 | 06:04 PM
  #298
canister's Avatar
canister
Go with the plain billet one. That way you can make it any color you want and its stronger than the plastic. Where are you going to mount it?
Old Feb 8, 2011 | 06:16 PM
  #299
beanhead6D5's Avatar
beanhead6D5
Get the BILLET!
Old Feb 8, 2011 | 06:48 PM
  #300
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Billet Jim!
