Swagger : Build Thread
Old Apr 17, 2011 | 10:01 PM
  #436
farmb0y's Avatar
farmb0y
Only 6 bolts?? So what's holding you back? Can't find them, can't get to them, don't have the right size wrench????
It's not a real ratrod till EVERY bolt is removed! LOL!
Old Apr 18, 2011 | 05:25 AM
  #437
rat49f6's Avatar
rat49f6
just waiting on that stage
the only bolts left are the 6 cab bolts
i need about 8 guys a full weekend of nice weather and the firewall finished and ill pull the cab to clean up and paint under it
Old Apr 22, 2011 | 07:32 AM
  #438
rat49f6's Avatar
rat49f6
Update:
Brackets are in for the 6 link
I've delayed myself again by deciding that I will use a obs axle
the Obs axle is 4" narrower and the same lug pattern as the Chevy front
Old May 2, 2011 | 08:23 PM
  #439
rat49f6's Avatar
rat49f6
pic of my engine in the back of Jasons excursion
Old May 3, 2011 | 06:40 AM
  #440
SkySkiJason's Avatar
SkySkiJason
Ahhh, good times! Yes - I am a crazy redneck, in case anyone was still wondering...
Old May 6, 2011 | 08:51 PM
  #441
slamed150's Avatar
slamed150
looks good. have you done any programing to the truck for more power, im assuming so since i see the a-pillar pod.
if you want another project, im selling mine unfinished.
btw i havent been on here is a long time and got parsed from the forum, had to resign up.
Old May 7, 2011 | 09:42 AM
  #442
rat49f6's Avatar
rat49f6
yes truck is running a dp tuner
also has :
Comp 910 valve springs with shims
Casserly 250cc/100% injectors
has van turbo now gonna have a 4294
99.5 updated
Terminator modded 17* hpop
what is ur project vehicle
Old May 7, 2011 | 10:32 AM
  #443
slamed150's Avatar
slamed150
its a 87 f-150 ext cab long bed. been dropped on bags for years. layes radius arms. i built it when i was 16 so it needs to be cleaned up, i started to do some but hard to work in a storage unit. i have lots of parts gatherd up including oem ford sheet metal(before it became extinct)
some specs include: duel 1/2" port slam spec bags. 8 1/2" smc valves. 8 3gal tanks. 2 setups for nitrogen. flush mount tonno cover. 40x40 sliding ragtop. brand new headlights. brand new ford oem hood,coresupport, rock guard. custom front bumper with billet grill and fogs.
i have some pics of it. if your interested email me and we can talk. or if you may know someone that may want it. cturnerwelding@gmail.com
i seen you have a couple projects in the garage. just putting it out there, cause i cant sell this to a normal person lol
Old May 9, 2011 | 10:19 PM
  #444
rat49f6's Avatar
rat49f6
rear suspension finally under way
still have to remove the spring perches and clean up the OBS axle
fron drivers side
the bar going across will be turned into a crossmember with driveshaft hoop
one side will be adjustable the other will be solid
Old May 9, 2011 | 10:35 PM
  #445
big poppa's Avatar
big poppa
"CUSTOM" nice work Jim....
Old May 10, 2011 | 04:23 AM
  #446
gbroehl1's Avatar
gbroehl1
Good work as always Jim. I work again this weekend, but would love to stop down again some time after that.
Old May 10, 2011 | 06:03 AM
  #447
rat49f6's Avatar
rat49f6
I know petey is coming down on the 20th... maybe we could tackle those last 6 olts and get the under side of the cab painted
Old May 13, 2011 | 08:06 PM
  #448
rat49f6's Avatar
rat49f6
gtg next weekend
https://www.ford-trucks.com/forums/1...l#post10338530
Old May 15, 2011 | 10:43 PM
  #449
rat49f6's Avatar
rat49f6
so this weekend was an epic fail
friday i went to the shop to strip the obs axle and get it to bare steel and found out both torches were empty
sat i was so discouraged that i drank heavily
today i returned to the shop with the torch from work and it last about 2 mins before also being out of BOTH GASES
so i cut the 2x2 link bars to length
while trying to notch the ends to fit around the bar ends i killed 3 2" hole saws and 1 1/2" Milwaukee hammer drill before getting one notched
Old May 16, 2011 | 04:18 AM
  #450
Towmanjbo's Avatar
Towmanjbo
Ouch, well that sucks!
