Swagger : Build Thread
Old Dec 5, 2010 | 05:25 PM
  #181
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Slamming Jim!
Old Dec 5, 2010 | 05:36 PM
  #182
brownie83's Avatar
brownie83
holy *****...that is "rockers scraping the ground"
you better give it some height when you come to spring fling...remember my road...
Old Dec 5, 2010 | 05:41 PM
  #183
twags6's Avatar
twags6
Thats what the air bag suspension is for. Speaking of which, are you converting the York compressor over to air or buying a kit? I'd love to see how you do that install.
Old Dec 5, 2010 | 09:06 PM
  #184
johnsteffy's Avatar
johnsteffy
Originally Posted by rat49f6
she does but she has rules
1.)buttons are not toys
2.) katie doesnt use power tools
3.) dont look at the welder flash(aka blue sparkles)
4.)dont look into the LED drop light
5.) no breaking windows
and she follows none of these rules... ever... unless shes too busy with doctor silver fox... haha
trucks looking sweet man, ill be down monday most likely
Old Dec 5, 2010 | 09:28 PM
  #185
rat49f6's Avatar
rat49f6
i gotta do ANOTHER alt on the whip monday WTF
but wed is def a go
PS everyone please rep John he has been a huge help to me during this build
Old Dec 5, 2010 | 09:31 PM
  #186
johnsteffy's Avatar
johnsteffy
but wed is def a go
another one? wtf?
go to the junkyard for one at this point. and dont forget to cut the rear seat in half haha
and thanks man, its been very enjoyably working on the truck
Old Dec 5, 2010 | 10:19 PM
  #187
sddesigns's Avatar
sddesigns
FTE Emeritus
Done Jim, John you the man!
Old Dec 6, 2010 | 06:58 AM
  #188
WA.Ranger's Avatar
WA.Ranger
Also Repped him!
Old Dec 6, 2010 | 10:09 AM
  #189
johnsteffy's Avatar
johnsteffy
hey thanks everybody who repped me, its much appreciated
Old Dec 6, 2010 | 10:33 AM
  #190
farmb0y's Avatar
farmb0y
Reps sent!! John's gotta be a good guy:
1- working on a PSD
2- willing to help LOWER a Ford PSD truck
3- willing to help Jim! (We all know he needs all the help he can get! LOL!)
Keep up the good work guys! Definitely enjoying the pics.
Old Dec 6, 2010 | 11:52 AM
  #191
rat49f6's Avatar
rat49f6
Adam u ready to sell me those wheels yet
Old Dec 6, 2010 | 10:07 PM
  #192
frdf250's Avatar
frdf250
1- working on a PSD
hahahahaha
Old Dec 8, 2010 | 08:30 AM
  #193
mueckster's Avatar
mueckster
Jim,
Here is the info you requested. Couldn't attach it to the PM.
Driveline Angle
Driveline angularity is the angular relationship between the engine crankshaft, the driveshaft, and the rear axle pinion. Factors determining driveline angularity include ride height, rear spring, and engine mounts.
Driveline Angle
Name:  driveline angle.gif
Item Description
1 Bottom of the frame (0° reference)
2 Engine crankshaft centerline
3 Engine angle (to frame reference)
4 Driveshaft centerline
5 Driveshaft angle (to frame reference)
6 Rear axle pinion centerline
7 Axle pinion angle (to frame reference)
Calculate the driveline operating angles as follows.
Name:  driveline angle 2.gif
Preliminary setup procedures.
Inspect the U-joints for correct operation.
Park the vehicle on a level surface such as a drive-on hoist, or back onto a front end alignment rack.
Verify the curb position ride height is within specifications with the vehicle unloaded, and all of the tires inflated to their normal operating pressures.
Rotate the transmission output yoke until vertical. This will simplify taking measurements.
Calibrate the special tool by placing tool on clean, flat level section of the frame rail and press the ALT-ZERO button.
Using the special tool, measure the slope of the components. Record the measurements and the direction of the component's slope.
Example for Calculating U-Joint Operating Angles
Attachment 30471
Item Description
1 Output yoke slope
2 Driveshaft slope
3 The driveshaft slope minus the output yoke slope equals the transmission/driveshaft operating angle
4 Pinion flange slope
5 The driveshaft slope minus the pinion flange slope equals the driveshaft/axle operating angle
Name:  driveline angle 3.gif
Calculate the difference in the slope of the components to determine the U-joint operating angle.
When two connected components slope in the same direction, subtract the smaller number from the largest to find the U-joint operating angle. When two connected components slope in the opposite direction, add the measurements to find the U-joint operating angle.
The U-joint operating angle is the angle formed by two yokes connected by a cross and bearing kit. Ideally, the operating angles on each end of the driveshaft must:
be equal or within one degree of each other.
have a three degree maximum operating angle.
have at least one-half of one degree continuous operating angle.
Driveline Angles Wheel Base (inch) Engine (L) Trans. Axle Ratio Angles at Maximum GVWR (Deg) Trans. Angles at Maximum GVWR (Deg) Pinion Angles at Curb (Deg) Trans. Angles at Curb (Deg) Pinion
4 x 2
137 7.3 4R100 3.73 1.50 1.93 0.20 2.01
Old Dec 8, 2010 | 12:53 PM
  #194
7.3 Rocket's Avatar
7.3 Rocket
Steffy is cool. Chris are you coming to the dirty jersey Christmas? Btw better you than me with all the math there, Jim.
Old Dec 8, 2010 | 02:25 PM
  #195
sddesigns's Avatar
sddesigns
FTE Emeritus
I had to rep Roland just because...lol
