Y'all want to see the picture's from the F-150 Test Drive Event....?
No. As Bill said, let's just see the "Cliff's Notes".
Just a couple good ones is all I'm willing to look at.
Anthony, if you're going to call yourself a photographer, this is something you're going to have to get used to doing. Not all of your shots are going to be worthwhile. In fact, most of your shots are going to go into the dumper, and you will be showing only your best.
Ansel Adams took hundreds and hundreds to get one or two, but those were spectacular, and he KNEW how to use a camera! So much of his stuff ended up in the trash can, but as well as knowing what to print, he knew what to throw away.
Hatches are battened down here, unless we have high winds, then I'll lose an already over-loaded lemon tree to an implosion, despite the internal stainess cables of support.
