new problem
Old Oct 22, 2010 | 03:18 AM
jims406rs's Avatar
jims406rs
new problem
did a coolant flush yeasterday and afterwards had an intermittant no boost problem. Now I have the exact opposite. very high boost all the time and constant turbo farts through the intake. im making 20 to 25 psi at 2000 rpm continuously. What the heck is going on? I did remove the ebp sensor when I removed the stat but it is firmly reconnected now. Would a bad ebp cause this? if I need a new one does anyone know a part number? is this a dealer only part?
Old Oct 22, 2010 | 08:22 AM
bismic's Avatar
bismic
Do you have an early '04 or a late '04 (where is your ICP valve)?
Old Oct 22, 2010 | 08:48 AM
npccpartsman's Avatar
npccpartsman
Can you scan the truck and see if you have an EBP code?? I would suspect a wire or connector problem or possibly a bent pin. Did you possibly remove and clean the tube while the ebp was out???
Old Oct 22, 2010 | 09:06 AM
moebdick's Avatar
moebdick
The EBP sensor info is used by EVRT to control boost, or at least it used to be. Supposedly some trucks were flashed to eliminate the EPB sensor, but I'm not sure which ones. Mine had to be replaced this past spring and I have an April '04 build, for what that's worth. Not sure what flash I have.
Old Oct 22, 2010 | 09:10 AM
bismic's Avatar
bismic
2003 and early 2004's (production through 9/2003) had the EBP input eliminated. I believe though an EBP valve still needs to be in place and connected for proper operation - even in these early year models.
OP - the connectors can get damaged as well as a bad sensor (as npccpartsman stated) - look it over real well.
Old Oct 22, 2010 | 11:29 AM
jims406rs's Avatar
jims406rs
its a 4/20/04 build date. icp sensor is in valve cover. i do have a ebp code. i have looked the sensor over and the pins and connector look fine.
Old Oct 22, 2010 | 11:34 AM
moebdick's Avatar
moebdick
What's the code?
Old Oct 22, 2010 | 02:18 PM
jims406rs's Avatar
jims406rs
just replaced the ebp sensor. seems to have fixed it and the code has not returned. I guess I must have damaged it somehow....expensive mistake....
Old Oct 22, 2010 | 02:21 PM
bismic's Avatar
bismic
Glad you got it fixed.
Old Oct 22, 2010 | 02:28 PM
moebdick's Avatar
moebdick
Good deal. I think they must get brittle from the heat. Mine got broken when they replaced my EGR cooler.
Old Oct 22, 2010 | 04:16 PM
jims406rs's Avatar
jims406rs
Thanks for everyone's help!
Deep South
Oct 1, 2014 01:32 PM
20powerstroke02
Nov 9, 2013 09:03 PM
wicks302
Nov 10, 2012 04:42 PM
gb'sfx4
Dec 23, 2010 06:37 PM
frdf250
Mar 31, 2010 03:10 PM
