broken ebp sensor
Old Dec 22, 2010 | 05:32 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
broken ebp sensor
I decided to do a coolant flush today & when I was taking the thermostat out I broke the ebp sensor off.
I drove it for about an hour with a gallon of restore in it & it runs fine, no codes with the ebp sensor un plugged.
will there be any issues , or did that strategy get removed from the '03s?
I'm in the middle of flushes now , so back to work.
Old Dec 22, 2010 | 08:15 PM
gearloose1's Avatar
gearloose1
Check the tech folder, think with it disconnected, it defaults to a value...
Old Dec 22, 2010 | 09:08 PM
gb'sfx4's Avatar
gb'sfx4
I'll look into it ..........thank you
Old Dec 23, 2010 | 04:53 AM
npccpartsman's Avatar
npccpartsman
On the 03's it was at one point flashed out of the strategy and other sensors were used to give an inferred value. If you don't have any running problems you MAY be ok.
Old Dec 23, 2010 | 06:37 PM
gb'sfx4's Avatar
gb'sfx4
no issues , the truck runs as it did before
Iaff113
Sep 11, 2014 01:58 AM
waterboy_fishing
Apr 25, 2012 10:33 PM
tm0231009
Nov 14, 2011 08:30 AM
ehgeeray
Mar 26, 2010 09:12 PM
eric777
Aug 11, 2006 01:01 PM
