HOW IT WORKS The Lowdown on Sway Bars
By -
50f2Petemcl
You look under your truck and see those bars going across from one control arm to another. They attach by a set of links and move with the suspension.
Those bars are your sway bars and they have a big job being attached to your truck. We’ll discuss this in a quick look into them in How It Works.
tarett-Sway_Bar11
First, let’s talk about its name. The sway bar goes under several different terms to describe it; sway bar, roll bar, anti-roll bar, roll control bar, and probably several more that we can’t recall all at once. However, all of those terms describe a part that does the job of controlling body roll as you drive around a corner. We’ll reference it as a “sway bar” for this article.
The sway bar only acts on roll, where the weight of the truck during a turn compresses the outside suspension (bound in suspension engineer speak) while inside suspension droops (rebounds). The sway bar does not act as the suspension travels evenly as it would in a bump situation where both wheels travel at the same time.
sway-bars-chassis-bracpromo
Roll can be controlled by the springs of your truck, however doing so would end up making the suspension very hard for that control. So, you’d probably end up bouncing your fillings out on a truck that uses its springs for roll control. Along with your occupants, wife, and cargo in the back.
How that sway bar acts on the suspension is determined by several factors: Bar diameter, arm length, and placement on the control arm. For the moment, we won’t take material that the sway bar is made of into consideration, though it is also a factor in the end though one you can’t really control since that’s up to each manufacturer both OEM and aftermarket. Just know that all sway bars are made of a spring metal.
The diameter of a sway bar is the first thing that will get changed from the aftermarket. The thicker the bar, the more stiff it is just as it is with a torsion bar. Essentially, that is exactly what a sway bar is: a torsion bar for roll control. Now, where this can differentiate is if the bar is hollow or not. A 26 mm solid bar will most likely be stiffer than a 26 mm hollow bar, for example.
Another factor is the length of the arm of the sway bar. In race cars you see this in the splined arm at the ends of the sway bar. Your OEM sway bars and aftermarket bars built to fit in the OEM position also have “arms”, though they are made into the shape of the sway bar.
What the aftermarket will do is add a few different holes at the ends of the sway bar where the sway bar end links connect and this changes the effective length. The shorter the arm (or closer the end links are to the center of the bar), the stiffer the sway bar acts. The further, the softer.
The arm is a lever and if you want to get an idea of how that works, take a ruler and try to bend it from several different lengths. You’ll see that it’s easier to bend the further away from the pivot you are.
front-swaybar
Finally, the position where the end link attaches to the control arm will affect how much the sway bar acts on the suspension. This is known as wheel rate and is calculated with this formula: Wheel Rate=Spring Rate*(Motion Ratio^2)*Spring Angle Correction. For a sway bar, Spring Angle Correction will be 1.
The motion ratio is the ratio between how much the spring is compressed compared to how much the wheel is actually moved. For example if the spring only compresses 0.6 inches when the wheel is moved one-inch, that would be a 0.6 motion ratio. This calculator can help: http://www.hypercoils.com/spring-calculator.
Find answers to your questions in the forum.>>
1950 Ford F2 photo courtesy of forum member petemcl.
Justin Banner is a regular contributor to LS1Tech and JK Forum, among other auto sites.
How to Guides
Read It
Read It
Rezvani’s Latest Post-Apocalyptic Monster Is a Ford F-150 Raptor Underneath
Read It
Read It
