Ford F150 with Lights Issues
Old May 31, 2026 | 10:49 PM
PT9er's Avatar
PT9er
1st Gear
Angry Ford F150 with Lights Issues
If anyone can suggest a fix for my 2014 F150 Supercrew Cab Lariat, having issues with interior lights and cab exterior lights stays on for a very long time before shutting off. And also my passenger rear door does not lock or unlock but by luck at times. To off I am also having issues with "Left and Right door ajar, alternatingly flashing on my dashboard until I press OK to each message, but both doors were close tight. Are any of these issues have any relations? Thank You ALL!
Old Jun 1, 2026 | 12:50 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
your truck thinks a door is open. hence the lights staying on 10 minutes until the battery saver circuit kills power. sounds like 2 doors at minimum
the door sensor is part of the latch. take a screwdriver and wd-40. spray the latch and try to flush it. cycle latch open/shut with screwdriver a few times. flush with wd-40. do this multiple times per latch. if you're lucky the sensor hasn't failed, it's just dirty. I've had great luck on many Fords with this trick
as for the lock, replace the lock solenoid. they're cheap (under $20). look for loose/pinched wires while in there.
Old Today | 03:13 AM
Vivian AUXITO's Avatar
Vivian AUXITO
PLATINUM SPONSOR
Yeah this is spot on. Seen this come up a lot on these Fords.
Usually ends up being either a sticky latch sensor or a tired actuator like you said.
Good chance a quick clean fixes it if they're lucky.
DaveGerdes
2021+ F150
15
Nov 28, 2024 01:46 PM
P4IN COMM4NDO
Jul 18, 2017 06:32 PM
casey99
2009 - 2014 F150
Jun 9, 2017 08:31 PM
ZaksEx03
Mar 3, 2010 01:10 PM
