1988 Ford Truck with an Explosive Problem
Poorly-maintained 1988 Ford ‘super duty’ with low-mileage has a battery problem that leads to a no-start condition.
Ford-Trucks.com is a great place for owners to seek help on how to fix problems with their own pickups, but there is so much knowledge on the website that professional mechanics stop in to ask questions of the community. Recently, a mechanic named “Pamela Kerr” posted on FTE‘s forum asking for help with a 1988 Ford Super Duty that came in for a brake job, but it grew into a much larger project.
When the mechanic wanted to find out if the problem being addressed with this 1988 Ford truck was a common one, she turned to FTE and the community was quick to help.
The Introduction
When the OP first posted her thread to the forum, she provided the following information on the situation.
Working on 1988 Ford F-Super Duty. It has 66000 miles, original everything, except those that I have replaced. This started with new calipers, replaced and it went smooth amazingly. However, went to start and it wouldn’t turn over. Tried to start and it blew the solenoid apart (never seen nothing like it). Replaced the solenoid, not only will it not start, when I turned it over the positive battery cable began smoking. I tried jumping the starter directly didn’t turn, so I know I need to replace but what is causing the load down on my battery….I hooked up everything correctly and made sure all contacts are clean…..any ideas please help, I’m getting to the point of beyond my pay grade.
The Community Responds
The first member to offer assistance was “ZombieF150”, who asked some basic questions.
Starter wasn’t seized before you started working on it? meaning it has been a running vehicle? no recent battery replacement? to rule out possibility of terminal being reversed.
The more info we have the better we may be able to noodle out what the problem is. Calipers have nothing to do with starting or not starting.
To which the OP provided this information:
Up until the solenoid blew, yes, the starter worked perfectly. No battery replacement either and no switched cables
And ZombieF150 replied with an array of advice over the course of a few posts.
I would check the fuses, in cab and under hood fuses first, and fusible links possibly. “subford” probably has diagrams and would be better at narrowing it down quicker than I, or maybe “sandymane” can help
If your positive wire is smoking it is possible there is a direct short. Too much resistance in the cable.
Pull your grounds and clean them. the ones coming from the battery,etc, double check your positives also and clean them. wire brush and wd-40 will do a passable job.
The OP also offered some input on how poorly the truck had been maintained for a 1988 with only 66,000 miles.
Thanks, gonna try your suggestions, I am thinking either I have a direct short or possibly a ground not effectively doing its job. To give you an idea of what I am dealing with, the gentleman who owns this vehicle knows nothing of vehicles, I checked the oil and dang near lost it on him, I’ll be changing that too——it’s so burnt and it’s as thick as latex paint and all or most parts are the original 1988 parts, I’ll be paying attention for possible avenues from you and others on the forum. God Bless and pray for me, I got to get it back on the road today.
The Problem is Solved
The good news is that a few hours after posting the initial question to the forum, the OP had figured out the problem.
Well, I got up this morning baffled and came to the forums for aid and I appreciate your help. Turns out it was the battery itself, replaced and she turned right over and thanks for the trick with the sea foam, much appreciated, I am sure I’ll be posting again…he has 4 more and none are at the moment running…..God Bless.
I replaced the solenoid, I believe the one I replaced blew because it was from 1988 and just old. When I replaced the solenoid it then wouldn’t start, which turned out to be the battery.
In the end, the problem ended up being an easier fix than originally expected, but this is a good lesson for those who run into no-start problems to start with the battery and work from there.
You must be logged in to post a comment.
