Help! 292 exhaust manifold needed
Old May 29, 2026 | 02:45 PM
willb1's Avatar
willb1
I need a passenger side exhaust manifold for a 292 V8 Medium duty. The one on my ’63 step-side F100 has cracked and is spitting flames. All I can find thus far are throw-aways left in the rain for decades. Even those have bolt hole damage.
Would appreciate any help locating one.
Many Thanks!
willb
Old May 29, 2026 | 02:58 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Place an ad in our Marketplace? That’s the best place, and frees up the Forums for questions and such. Also, try Slick 60’s Trading Post, on FaceBook.
You could also get rid of those restrictive manifolds and go with a set of Ramhorn manifolds if you’re flush with cash.
Old May 29, 2026 | 05:51 PM
willb1's Avatar
willb1
Thanks, ibuzzard. I’ll check out the facebook lead. Would love ramhorns but my 3-tree **** is in the way for exhaust. I guess I would have to swap transmissions for a stick.
willb
Old May 29, 2026 | 06:24 PM
john jamieson's Avatar
john jamieson
Have you posted down on the Y-block engine forum?
Old May 29, 2026 | 07:31 PM
ibuzzard's Avatar
ibuzzard
willb
Not sure of your meaning, since your naughty word was censored. Are you saying your shift linkage would prevent using ram horn manifolds? I’d like to see some photos.
Nothing looks better on a Y-Block than period correct ram horns, they flow much better than the stock set-up with that crossover pipe, I’m told not far behind headers. Had them on my previous 59 F250.
But ya gotta have the Doh-Re-Mi. I think John Mummert still sells them?
Old May 29, 2026 | 07:45 PM
willb1's Avatar
willb1
Naughty word was “shift” but I misspelled it. Geez. My 3-on-a-tree transmission linkage would be in the way of an exhaust pipe for a ram horn on the driver side… I would think. When looking at it I dont see any clearance for the pipe. I sure wish I could do it. I think I would have to replace the 3-tree with a straight stick.
Old May 29, 2026 | 07:47 PM
willb1's Avatar
willb1
I will definitely call Mummert and cry on the phone to him.
Old May 29, 2026 | 07:48 PM
willb1's Avatar
willb1
No, but I will now. Thanks for the tip. Still new here.
Old May 29, 2026 | 07:59 PM
willb1's Avatar
willb1
ibuzz, how to i get to the “Marketplace?” I will definitely do so.
Old May 30, 2026 | 09:18 AM
Muppy1840's Avatar
Muppy1840
I might have one here. I’ll have to check later today. Doug.
Old May 30, 2026 | 10:07 AM
willb1's Avatar
willb1
Many thanks!
Old May 31, 2026 | 04:40 AM
Nevada51's Avatar
Nevada51
Here was I thinking I'd get ram horns one day....but not if they interfere with the shift linkages for the three-on-the-tree! Did John - or can someone - confirm they wont work with a column shift manual?
Old May 31, 2026 | 07:35 AM
skidoorulz's Avatar
skidoorulz
The exhaust pipes go far enough straight down from the center of the manifold then make a 90 degree turn back and go under the transmission crossmember. There is no way they should interfere with the shift linkage.
Old May 31, 2026 | 07:44 AM
willb1's Avatar
willb1
I would sure like to see some pics or diagrams of that.
Old May 31, 2026 | 02:20 PM
skidoorulz's Avatar
skidoorulz
