1977 F150 4x4 - Another Project
Old Dec 24, 2021 | 09:34 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Cool 1977 F150 4x4 - Another Project
Drug me home a project. Got for a great deal, most of the parts are there, and what isn't I think I have on the shelf.
supposedly c6 and 351m have a rebuild on them but haven't been fired. Engine turns. - I think the crank is broken
Plan is to fire it with front clip off and run it like the cam has never been broke in. Then pull it and go to cleaning/prepping.
Missing some small misc things.
I happen to have a 460 out of a 1999 propane generator with 320 hrs on it, some ported C9ve heads, roller rockers and some other goodies to go in it. Trying to decide how far i am going to go with cleaning things up/painting. Plan to turn loose my 4 and 7 year olds with some paint on the frame and let them help!
Plan is just a good driver, probably 2" lift with 35's.
Came with 5 matching wheels, extra door and hood.
Old Jan 22, 2022 | 04:47 PM
KubotaOrange76
Finally got some time to pull the bed and get some cleaning done. For some reason someone torched off the rear shock mounts at frame? weird
My wife lovingly named the truck Brandon
Old Jan 22, 2022 | 05:57 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The rear shock mounts are normally rivet mounted to the frame like an upside down cup and the very small drain groove (on the mount) gets clogged easily and they rust out and start to eat at the frame. Some folks do not like grinding rivets, so they torch them off. You can see the heat marks on the frame in your pics. Come time to replace the the mounts grinder the drain groove to be bigger and just bolt them back on. Nice project for sure.
Old Jan 22, 2022 | 06:47 PM
KubotaOrange76
Thank you
I remember now always having to wash and flush those mounts after playing in mud on previous dentsides.
Is that apprx 2” hole behind the upper shock mount factory? I don't remember seeing that on other trucks.
Old Jan 22, 2022 | 07:35 PM
77&79F250's Avatar
77&79F250
Not sure I have to go look...ok even better I found a pic on my phone of a recent parts truck. Yes the hole is normal.
Old Jan 22, 2022 | 07:43 PM
KubotaOrange76
I answered my own question, dont know why i didnt think to look. It jumped out at me for some reason
Old Jan 22, 2022 | 07:47 PM
77&79F250's Avatar
77&79F250
Not my stuff, and he is willing to mail them. https://springfield.craigslist.org/p...436129147.html
That beats cutting them off another truck. And you can go eyelet to eyelet on the shocks.
Old May 16, 2022 | 08:36 AM
KubotaOrange76
Finally making some progress, cleaned out fuel lines, replaced rubber, obviously new tank and sending unit. Frustrating new unit came sized for 5/16" line.
Got old exhaust cut out and frame half assed painted. Installed stainless braided rear hose i had leftover from another project.
Have a plan to fab up shock mounts for new takeoff super duty shocks i already have. Going to pull good driveshaft and yokes from my good parts truck to replace the sloppy slip yoke/cv shaft and rear gets a long AAL for lift i have leftover from another project. I have super duty shocks to go up front and will likely just do c bushings and 2" front coils along with going thru and freshening up front end, brakes etc.
As much as I want alum heads/intake the 460 it getting some c8 heads I have and SCJ iron intake. inside engine is pristine due to propane industrial application and only slightly over 300 hrs on it. I will be added a mild voodo cam and fenderwell headers. I already have aluminum roller rockers and a 800 holley to go with it.
Old Jun 13, 2022 | 09:53 AM
KubotaOrange76
Cut shock mounts off parts truck and converted them to use double eyelet shocks off the rear of a super duty I had laying around. Bolted on with hardware from my used bolt bin. I tried to drill some holes to drain the mounts where they like to build up mud.
I swapped the driveshafts between parts truck and this one as well as yokes and put in new seals. went ahead and pulled the old 1310 and 1330 from the donor shaft as the rear had corroded from sitting with no bed outside for awhile, wound up having to torch the rear 1330 to get the last part out. Sanded down the shaft and got it painted. Have some spicer life series joints coming for the front and rear shafts. Picked up some hardware to bolt down the bed, so that will be next along with finagling a new hinge mount for the tailgate.
Old Jun 30, 2022 | 07:42 AM
KubotaOrange76
Got a whole disassembled late 80's carb'd 460 for $300, i just wanted the performer intake.
I picked the drive shafts from my parts stash with the tightest slip yokes and cleaned/painted. They are ready for new life series ujoints.
Old Jun 30, 2022 | 09:03 AM
Greaser007's Avatar
Greaser007
Looking good for all your efforts. Keep moving forward.
Old Jun 30, 2022 | 09:08 AM
KubotaOrange76
slow but steady wins the race right? Thanks!
Old Jun 30, 2022 | 11:13 PM
Evan76's Avatar
Evan76
Is it going to turn Orange?
Im jealus
Old Jul 1, 2022 | 09:36 AM
KubotaOrange76
Nah not this one, Wife will eventually pick a color. For now plan is to get it running, driving and reliable, then worry about body work/paint at some point. Whatever I do with paint/body, it will be sub par
Old Jul 10, 2022 | 07:37 AM
KubotaOrange76
Little more prgress, moving so packing the non uhaul stuff
lid flipped 🤣
Wasp tried to take it over
5th wheel hitch makes good tie down
Will Get bolted today
