Additives
Old 12-01-2016, 11:08 PM
Vinford's Avatar
Vinford
Vinford is offline
Additives
2016 F350
Ive owned lots of diesels and have always used additives for water and ice?
Live in BC where it gets pretty cold and putting additives in all types of fuel is very common.
I asked the dealer what I could use and he said nothing?
Anyone know how it could hurt anything?
Old 12-02-2016, 05:07 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Ford sells PM-22 and PM-23 Check page 58 of your diesel supplemental owner's manual. I believe PM-22 is more of a cetane booster than a demulsifier product. PM-23 is a product for gel prevention in addition to cetane boost. I use the Stanadyne Blue (year round) and Red (summer) for cetane boost and demulsifier to help remove any water.
PM-22
https://www.fcsdchemicalsandlubrican...nce%20Products
PM-23
Old 12-02-2016, 06:05 AM
smlford's Avatar
smlford
smlford is offline
Another Stanadyne fan here. I run the performance formula year round.
Performance Formula « Stanadyne Additives
Old 12-02-2016, 07:34 AM
treatcg's Avatar
treatcg
treatcg is offline
I like the Motorcraft juice. I keep all my receipts too in case of a warranty issue.
Old 12-02-2016, 08:27 AM
Pocket's Avatar
Pocket
Pocket is offline
There is a way that certain additives can hurt these motors.
Ford, and other auto makers, all have recommendations for the type of additives to use, if any at all. These are additives that improve cetane, lubricity, and when necessary..... anti-gel. That's it. They do not recommend any additives that do anything else.
The additives that can be harmful are those that go above and beyond what the auto manufacturers recommend. I'm talking about the additives that contain chemicals and products designed to clean injectors and injection systems, and/or designed to emulsify/demulsify water.
Cleaning agents can actually reduce lubricity in certain situations, like in the HPFP. That's because these agents are typically alcohol based. HPFP setups in common rail systems are not very tolerant of these alcohol based solvents.
Agents that emulsify/demulsify water can actually push water past the W/S and into the HPFP, injectors, etc. This prevents the W/S from doing its job properly, and contaminates the high pressure fuel system which over time can lead to eventual failure.
With proper maintenance, there is no need to use alcohol based solutions to clean out the fuel system. There is also never a need to emulsify or demulsify water. Let the W/S do it's job like it's designed, and maintain it properly by draining it periodically.
Old 12-02-2016, 09:48 AM
HouseMouse's Avatar
HouseMouse
HouseMouse is offline
Well said and Thank You for changing my mind about Additives. I'm now clean and sober.
Old 12-03-2016, 03:11 AM
Bohen's Avatar
Bohen
Bohen is offline
1oz of Essential Lube and 2oz of Power-Kleen by hydrotex at every fuel up and its fine to run in our Powerstroke fuelrail system . The garbage company that I work for has been these products for 10 plus years
Old 12-03-2016, 11:39 AM
hoseclamp's Avatar
hoseclamp
hoseclamp is offline
The fuel up here (I'm from Vanderhoof) just like your area is arctic fuel in the winter. I don't add anything for water, just opti lube summer formula for cetane and lubrication. Never an issue.
dhag911
03-06-2018 01:18 PM
Dave Dirsa
6.4L Power Stroke Diesel
26
01-06-2016 08:08 AM
cavementech
6.7L Power Stroke Diesel
22
08-29-2015 09:33 AM
diamondrcattle
17
03-07-2014 08:21 AM
6litrefan
05-30-2009 10:02 AM
Quick Reply: Additives
