6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
cetane boost additive
Old Jan 16, 2014 | 08:05 PM
diamondrcattle's Avatar
diamondrcattle
What do you think of power service cetane boost in gray bottle?? Ford mechanic reccomends and hear ads on farm programs a lot. Is it needed?? How often????
We run several John Deere engines from 1-10 years old. Interesting how little fuel additives are promoted by Deere. While they seem to be the thing for pickups.
Old Jan 16, 2014 | 08:15 PM
wait4it's Avatar
wait4it
I use PS grey bottle every fill up during warm weather, and use PS white bottle during colder weather to help prevent fuel jelling. PS is used by a lot of diesel owners, and has been for years. Good stuff.
Old Jan 16, 2014 | 08:44 PM
golfmedik's Avatar
golfmedik
I do the same. I've been using Diesel Kleen for years.
Old Jan 17, 2014 | 12:03 PM
reaganla's Avatar
reaganla
It provides lubrication to the fuel system which the ultra low sulfer diesel lacks. Keeps injectors happy
Old Jan 17, 2014 | 12:15 PM
ssharber's Avatar
ssharber
I use it every fill up also. Once, for a whole month during the summer, I was unable to use the additive and noticed not only more frequent regen times but the truck just didn't run as well. Almost like it lacked a little power. And with the lower lubricity content of the ultra low diesel fuels we have to run, it's imperative in keeping the fuel injectors AND the fuel pump happy. You don't even want to know what the high pressure fuel pump will cost you to have Ford replace it. So it's cheap maintenance if you want longevity out of your engine. And who doesn't?
Old Jan 17, 2014 | 02:18 PM
deerslayer64d's Avatar
deerslayer64d
I use the cetane boost in the clear Bottle from the Ford house every fill up , not sure it helps or not but they say it keeps the fuel system lubed ?
Old Jan 17, 2014 | 05:40 PM
matted2thefloor's Avatar
matted2thefloor
Same here, either the Ford stuff or PS grey bottle. I'm in the south so no gelling worries for me!
Old Jan 17, 2014 | 08:46 PM
RM2738's Avatar
RM2738
I've been using PS since truck was new. No need for winter formula. I occasionally run a couple pints of marine two stroke in a tank (Not recommended if your DPF is still in place).
Old Jan 18, 2014 | 11:18 AM
PSDx3's Avatar
PSDx3
Use PowerService DieselKleen in every gallon of fuel. Peterbilt has 980,000 mi. with no fuel system problems at all. Also run it in my 6.4. Have a 1000 gal. tank at home and put the concentrate in before every bulk delivery. If you can find an oil distributor who sells the 2 1/2 gal. jugs of concentrate you will save over 50% on the cost. I think the concentrate is about 1 oz. to 10 gals. of fuel. I have been told the Ford brand diesel fuel conditioner is PowerService in a Ford bottle.
Old Jan 18, 2014 | 11:58 AM
RM2738's Avatar
RM2738
Sweet!
Thanks for the info. I wasn't aware they made such a thing. Looks like it will run about $50 and treat 1000 gallons! Might need an eye dropper for my measly 30.5 gallon tank.
Old Jan 18, 2014 | 12:49 PM
USArmyTaterness's Avatar
USArmyTaterness
In these modern diesels you do not "need" a cetane booster of any kind in the winter to avoid jelling I prefer Howes treatment I have had better results and havent had to replace a single filter due to jelling since I switched from power service
Old Jan 18, 2014 | 12:51 PM
RM2738's Avatar
RM2738
Or just move to Texas! Never even concerned about the remote possibility of gelled filters.
Old Jan 18, 2014 | 01:04 PM
USArmyTaterness
Too many people in Texas I will stick to Wyoming
Old Jan 18, 2014 | 02:31 PM
URDADDY's Avatar
URDADDY
Depends where in Texas, Im in the panhandle of Texas and it gets plenty cold here at times. And not to many people in Texas by most standards, but by Wyoming standards Im sure we are way over populated.
Old Jan 24, 2014 | 02:51 AM
aquaman's Avatar
aquaman
I've been using DK for quite some time and have noticed no benefit in mpg or regens. It does seem to make the truck run bit smoother though.
I think it also depends on where you get your fuel. I use Shell or Chevron almost exclusively now. I had a crap tank of Valero diesel when I tried to save a few $$ because it was cheaper, but that was a mistake.
