1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Ts chip questions!
Old 10-21-2016, 06:32 PM
texbigred1's Avatar
texbigred1
texbigred1 is offline
Ts chip questions!
Can any one help. First diesel and it came with this chip. Also has a six position **** and the Po told me the settings. He said the check engine light was on because of it. Will it also cause the od off light to be on? I still have od and it shifts fine. But the off light stays off. Then sometimes it will be off. Never flashes like a code. Any ideas. And can I take the chip off with out putting something back in the hole. I want to see if the lights go off if I remove it. Thanks in advance from a diesel noob
Old 10-21-2016, 06:33 PM
texbigred1's Avatar
texbigred1
Btw 2002 f250 4x4 7.3l
Old 10-21-2016, 06:41 PM
lllateralus's Avatar
lllateralus
lllateralus is offline
Yes, you can remove the chip. Drivers side foot well, right next to the E-brake is the PCM. (computer)
DISCONNECT BOTH BATTERIES. DO IT. DON'T SKIP THIS STEP. YOU CAN KILL THE PCM.
One 10mm bolt secures the large wiring harness connector through the firewall on the ENGINE side to the PCM.
With a 10mm socket (1/4 is the easiest in this case) loosen that bolt until you can pop the connector off.
Once disconnected, loosen the 8mm (I think) bolts by the E-brake securing the PCM and pull it out. Remove the TS Performance chip and throw it in the nearest garbage can.
Take note of the orientation of the PCM inside the black plastic housing and make sure it goes back in the same way... (you will see what I mean)
Old 10-21-2016, 06:54 PM
texbigred1's Avatar
texbigred1
So the chip is no good. Programmer better and which one.
Old 10-23-2016, 03:39 PM
lllateralus
The TS chip is not a bad chip. But, if you don't watch those EGT's like a hawk on the higher settings, it will kill your motor in no time.
I roasted my 159K mile 7.3 towing with the TS chip. (complete rebuild, holes burnt through piston #7) Every piston cracked.
Old 10-23-2016, 07:23 PM
texbigred1's Avatar
texbigred1
I do have a 4inch turbo back exhaust. And Havnt run much on anything but stock. Do want to get a gauge pod and get a boost gauge and egt maybe volts also?
Old 10-23-2016, 08:01 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is online now
Token Redneck
Get a trans temp gauge if you have an auto, the 4R100 doesn't like getting hot. Common mod is a larger plate cooler from a 6.0/5R110W, it has 26 rows versus whatever tiny thing the 7.3 came with. There's also a popular valve body mod out there. I would be more worried about getting the truck set up to run well then adding the chip back, or getting a different one.
https://www.ford-trucks.com/forums/1...l#post13273034
http://www.riffraffdiesel.com/john-w...00-valve-body/
Old 10-23-2016, 09:52 PM
texbigred1's Avatar
texbigred1
The Po said he had the trans rebuilt and has a better torque converter and some kind of shift kit or valve body work I'll ask him for sure which.
Vinford
12-20-2011 07:57 PM
Orr353
07-03-2011 02:39 PM
Jesse Zimmerman
05-19-2010 10:35 PM
99350Ron
02-03-2010 04:04 PM
winn9524
Computer Chips & Tuners
01-15-2007 02:16 PM
Quick Reply: Ts chip questions!
