- Fuel Leak on '77 F250, Dual Tank Selector Valve??
- behind seat fuel tank
- carb adjustment
- Replumbing fuel lines
- Stainless braided hose ?
- Same Problem Different Day
- Fuel Injection Swap
- Four o2 sensors on 96 5.8L - rear two ?
- Fuel Air ratio question
- Fuel injector filter replacement question
- help
- 4160 holley fast idle cam
- I got a Question?
- IS this thing lean?
- vacuum problems!
- Fuel line cracking every 6 months.
- Changed Gas Tank....Now Wont Start
- Holly VS. Edelbrock
- motorcraft vs. holley 2bbl??
- STP Fuel injector cleaner works really well!!
- Problem Is Back
- Carter YFA fuel return?
- Holley 1850 auto kickdown conversion?
- Question?
- Carter AFB rebuild
- fuel gauge not reading properly in 90 302 f150
- non-emissions carter yf exploded diagram wanted
- 92 F150 dual tank fueling troubles.
- Has anyone used this carb/ intake combo?
- Too Big Carb ?
