Carb Spacer Best Material?
Old Jul 3, 2007 | 08:19 PM
bobpearson90278's Avatar
bobpearson90278
Question Carb Spacer Best Material?
Ok so whats the best material to get a carb spacer in?
I looked through the Summit Racing catalog and they have the following materials:
Wood-fiber
Aluminum
Phenolic
Plastic
I'll probally be doing a 1'' spacer on a 4-barrell 351w in a '84 E150.
Thanks in advance for the input.
Old Jul 4, 2007 | 01:06 AM
LxMan1's Avatar
LxMan1
I would go with the Phenolic. It will isolate heat from the carb better.
Old Jul 4, 2007 | 02:22 AM
75F350's Avatar
75F350
For a 1" spacer I would consider a 4 hole phenolic spacer.
Phenolic provides the greatest heat isolation. Aluminum transfers too much, plastic is tough to seal after a few heat cycles, wood,,,,,is wood, yeah.
Additional plenum volume with the velocity of the 4 hole spacer is better achieved by using phenolic.
Old Jul 4, 2007 | 10:37 AM
bobpearson90278
Thanks guys for the input. Any brands that is prefered? I'm looking at eh Edelbrock spacers, their like $30 for the 4-hole Phenolic.
Old Jul 4, 2007 | 11:33 AM
LxMan1's Avatar
LxMan1
Edelbrock makes a good product.
Old Jul 4, 2007 | 12:25 PM
75F350's Avatar
75F350
If you have basic tools and can drill a few holes, you can make several for the same money.
You can use a gasket as a template, and cut one yourself. The material itself is not very expensive. If you are only making one, it may not be worth the effort, but if you have a couple of buddies that would like them too, you could make a buck or two.
Old Jul 4, 2007 | 01:31 PM
bobpearson90278
That would be a cool deal to do, although most of our tools are in storage 10 hours away. I will probally just buy the Edelbrock stuff.
carbs & chrome
20
Apr 23, 2015 06:48 PM
sseebart
Nov 6, 2014 09:43 AM
rews2
19
Oct 15, 2014 01:22 PM
gwhpnut
Feb 28, 2011 09:32 PM
proteks
May 31, 2004 11:22 PM
