fuel switch
Old Jul 11, 2007 | 12:23 PM
junkenstien's Avatar
junkenstien
fuel switch
I have a 1977 F250 with dual tanks. I have discovered that a previous owner? has disconnected the fuel lines from the switch that is located under the cab on drivers side. The switch has an inlet on each side with one having two ports. My question is which fuel line goes where. on the port that has two positions one is marked aux is this the inlet for both tanks?
Old Jul 11, 2007 | 05:30 PM
LxMan1's Avatar
LxMan1
Should have 2 in and 1 out. I believe that AUX would go to the front tank since the rear tank is standard on the truck.
Old Jul 12, 2007 | 07:17 AM
junkenstien
thankyou for your help
Old Jul 12, 2007 | 07:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975/77 F100/350 fuel tank selector valve
The valve may have been disconnected, because it failed. The valve is still available from Ford.
1975/77 F100/350
D5TZ9189B .. Fuel Tank Selector Valve -marked: D5TB-9F271-AA
FTE sponsor DIRECTFORDPARTS gives a parts discount to members, and shows the valve at $91.17 List Price / FTE Member Net $64.44
Old Jul 13, 2007 | 12:12 PM
junkenstien
thanks bill
Rippin6Gears
Aug 23, 2016 07:17 PM
coonhunter
Mar 22, 2016 01:00 PM
brianm767
1983 - 2012 Ranger & B-Series
Feb 13, 2016 08:30 PM
jaspirr
Apr 18, 2010 01:07 PM
SexyMF150
Apr 4, 2004 08:31 PM
