- A/C ???1994 F 150 5.0 -2wd ext cab-
- Heater and Power Window Switch Not Working
- Radiator Coolant Additive's ?????
- Buying R134a
- stops blowing air thru vents
- 2000 f 250 AC Problem...
- Bad Smell
- front cold, rear hot
- Cooling fan???
- 87 ac line to a 86
- A/C Compressor Noise; Over Pressure? (on a '75)
- Intermittent AC Operation - now none but coil is cold
- Jumping the A/C Compressor
- Update on 2 AC jobs for weekend
- 1997 explorer A/C problem
- HOT AIR - MAX A/C - 97 5.0 Explorer
- 302 overheating
- 134a Converson gone bad
- 1992 Explorer XLT 4.0v6 134a question
- 1991 ford f-150
- A/C diagnosis - help appreciated
- compressor clutch messed up..A/C always on....
- Heater Problems 67 F100
- 2 AC repairs to do this weekend...Need Help
- AC won't shut off
- A/C quits cooling after being on for a couple of hours
- Low and High end?
- Recommendations for a small coolant temp gage(non electrical if possible)-E 150 5.8l-
- Had Cold Air . . Then No Cold Air??!!
- air only blows from vent no matter what
