Buying R134a
Old Jul 15, 2004 | 03:51 PM
I LUV WI's Avatar
I LUV WI
Buying R134a
Went to my local NAPA to get a recharge kit like in the Haynes manual and they said they can't sell the stuff in WI. Are alot of states like this? Where do you guys get it? I just wanted to add 1 can to my 99 F150 w/o having to take it to the garage.
Old Jul 15, 2004 | 03:58 PM
Pikachu's Avatar
Pikachu
NAPA, anywhere but Wisconsin, apparently. But what makes you think you need to add refrigerant? Have you checked the system pressures with a set of manifold guages?
Old Jul 15, 2004 | 04:16 PM
I LUV WI's Avatar
I LUV WI
After reading the Haynes manual that is what I figured it needed. Just not blowing as cold as it use too. I was thinking I would add 1 can and see what happened. Haynes doesn't go into using guages so I would know what to do there.
Old Jul 15, 2004 | 06:32 PM
F150'89's Avatar
F150'89
You can buy R134a in WI if you are certified, you can go to www.imaca.org and print out the study guide. Then use you credit card for the $15 fee and take the test. You will need a gauge set to ad the correct amount R134a.
Old Jul 15, 2004 | 10:09 PM
Pikachu's Avatar
Pikachu
If it isn't blowing as cold as it used to, it may not be the refrigerant charge. My truck is also a '99 and cleaning the accumulated glop out of the evap coil helped a lot. It really isn't a good idea to add refrigerant without a way to monitor the pressures. You may actually be able to rent (or possibly borrow) a set of manifold guages from a local parts store. Some A/C shops will check the system pressures for free, too. Adding refrigerant actually increases the temperature of the evap coil while the compressor is running.
Old Jul 16, 2004 | 06:56 AM
HomerWinzlow's Avatar
HomerWinzlow
You need certification to buy R134? I guess it varies by state, but my state only requires that if you buy R12.
Old Jul 16, 2004 | 08:11 AM
I LUV WI's Avatar
I LUV WI
Is the evap coil the one in front of the radiator? If not where is it located?
Old Jul 16, 2004 | 10:21 AM
Pikachu's Avatar
Pikachu
The one in front of the radiator is the condensor, you can blast it out with a garden hose if it has leaves, bugs, etc. in it. The evaporator is the one in the box at the firewall with the heater core. You may be able to remove the blower motor and get a look at it. Most hardware stores sell cleaner for A/C system coils. There may also be other causes for the system not being as cold as it once was. Some of these are: blend door or heater core valve not fully closing, failing compressor, fresh air door not closing all the way. If it were me (as it recently was), I would start by checking the pressures. It certainly can only help to clean the evap coil, low cost process and it may be most of the cause.
Old Jul 16, 2004 | 10:37 AM
I LUV WI's Avatar
I LUV WI
I went out and took a closer look. Condensor is clean. Started truck and watched the compressor and lines. Compressor cycles on and off at about 4 second intervals, is this normal? The lines going from the condensor to the evap had a major temp diff. In fact water was dripping off the cold one. The drain from the evap, I'm guessing this is the hard metal one by the tranny, was not dripping, truck ran for 5 min on max a/c. There was however water dripping off the heat shield for the cat. I'm guessing this was off the line going through the firewall. I found the evap. How hard is it to get to it? Does the lower half of the dash around the glove box come off and do I need to worry about the air bag as I do this? What would I most likely find in the evap that you were talking about? I appreciate all the help. If it matters the truck is a 99 F150SC 4x4 w/ 5.4L
Old Jul 16, 2004 | 04:36 PM
Pikachu's Avatar
Pikachu
OK, now we're getting somewhere. No, the compressor should not be cycling like that at idle. The water dripping is mormal, and is the condensate draining off of the cold evaporator coil. The lines going to the evaporator should be cold (one more so than the other), and the condensor lines will get quite hot.
The cycling can be caused by several things, low evap coil temperature, low pressure, high pressure. These all call for checking the refrigerant pressures. If you absolutely cannot do that, here is what I might try, although it would probably still be against my better judgement. I would add small amounts (like 0.1 lbs.) of refrigerant at a time. If the cycling reduces or stops, the system may have been undercharged. If it increases, could be overcharged or have a restriction. If the compressor is noisy, it may be puking pieces of itself into the orifice tube screen, causing restriction.
Old Jul 16, 2004 | 05:08 PM
I LUV WI's Avatar
I LUV WI
Time to go to the garage for a guage check. I started trying to get to the evap and it is a pain in the azz. Have about 100 screws out and probably 100 more to go. Will put what I have back together and make an appointment.
Thanks much.
Old Jul 16, 2004 | 09:38 PM
Pikachu's Avatar
Pikachu
Probably the easiest way to get to the evap coil is through the blower motor opening in the engine compartment. I haven't done a cleaning on an F150, but that was how I got to it on a 350.
Old Jul 17, 2004 | 11:08 AM
hhott71's Avatar
hhott71
R134a must , let me stress this MUST be precisely measured into the system.
An overcharged system will result in inferior cooling and decreased compressor life.
There is absolutely no way to measure the amount of a 12oz can actually gets into the system
There is no way to know if it needs 12 or 20 oz.
Take it in, have it evacuated and charged, With a charging cylinder.
Tossing cans into an AC is not how its done.
I know many have done it.
Many have also used chewing gum and bailing wire to fix other things doesn't make it right.
Old Jul 19, 2004 | 10:37 AM
jessfactor's Avatar
jessfactor
i used one of those cans, but i have a guage. i only used part of the can.
montego69
Ford Truck Parts for Sale
Jan 13, 2016 02:06 PM
montego69
Oct 13, 2015 02:58 PM
Trashyvixxen
Aug 18, 2012 06:26 PM
major dad
Wisconsin Chapter
Nov 5, 2007 09:07 PM
xpshooter
Offroad & 4x4
Feb 5, 2007 01:45 PM
