Trans O/D light flashing
Old 10-02-2009, 09:08 PM
dddenio's Avatar
dddenio
dddenio is offline
Just replaced transmission, but the OD light is flashing, where should I look? Any ideas?
2001 v10
Old 10-02-2009, 09:52 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
bring it right back to the place you got it replaced. should have a warrenty? but you could pull the code and see what its doing.
Old 10-03-2009, 12:40 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
You need the code to ascertain why the trouble light was activated.
Like Alaska posted, take it back to the place that replaced the trans and have them diagnose it.
Stewart
Old 10-03-2009, 10:41 AM
dddenio's Avatar
dddenio
dddenio is offline
Sorry guys, I should have gave more info.
I bought a used trans from a reputable salvage yard with 36,000 miles on it and I need a little more info on this OD light flashing thing or how to pull the codes.
Thanks
Any trans guys on here?
Old 10-03-2009, 01:27 PM
Stewart_H's Avatar
Stewart_H
Mark Kovalsky posts here and he's a retired Ford trans engineer, but I'm sure he's gonna need more info just like we do.
You need to find someone with a PSD compatible code reader like a Predator, SCT Xcal II, or Auto Enginuity tool.
The regular scanners you can use at Autozone and Kragens don't work with the PSD's.
Once you find a scanner that will read your codes, post them up here or in the 7.3L PSD forum so we can help.
Stewart
PS - The reason the OD light is flashing is because you are setting a trans related code. The SES light in the dash is for engine related codes and the OD light flashing is for trans codes.
Old 10-03-2009, 05:09 PM
jpr38057's Avatar
jpr38057
jpr38057 is offline
Was the light flashing before you replaced the transmission? If it was the original code is still in there and needs to be cleared.
Old 10-03-2009, 08:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
Stewart
That's what I would have said.
Old 10-05-2009, 08:36 AM
Excursioncamp's Avatar
Excursioncamp
Excursioncamp is offline
I too will be interested in the diagnosis of this issue. This happened to me for the first time (OD light flashing) on my '02 PDS while pulling through the Smoky mountains this weekend. I've pulled a 32 ft. trailer since 2003 and have never had any issues with the transmission.
I've got a DP Tuner with 40 HP tow, and I locked out OD for the mountain climb. Just a little while later, after OD was unlocked, I noticed it flashing, and when it shifted to OD, it was a very hard shift. After getting to the campground, shutting it down, then restarting it, I never had any problems all weekend long or on the way back home.
Not sure if my transmission is going out or some fluke happened. I've got 145k miles and usually it tows like a dream. I've had regular transmission maintenance performed, but may take it in and have it checked out soon.
Old 10-05-2009, 11:21 AM
dddenio's Avatar
dddenio
dddenio is offline
When the original Trans failed it Displayed
These codes:
P1000
P0741
P1744
PO740
P0743
P0750
P0753
P0755
P0758
P1746
P1754
So I cleared these codes and all came up again except P0741 & P1744
These codes with new trans:
P1000
PO740
P0743
P0750
P0753
P0755
P0758
P1746
P1754
Mark, I'll edit this post and input the descriptions as well.
Old 10-05-2009, 12:51 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
New Codes:
P0740 Torque Converter Clutch Circuit Malfunction
P0743 Torque Converter Clutch Circuit Electrical
P0750 Shift Solenoid A Malfunction
P0753 Shift Solenoid A Electrical
P0755 Shift Solenoid B Malfunction
P0758 Shift Solenoid B Electrical
P1746 Electronic Pressure Control Solenoid - Open circuit
P1754 Coast Clutch Solenoid circuit malfunction
Old Codes:
P1744 Torque Converter Clutch System Stuck in Off Position
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
Old 10-05-2009, 07:26 PM
Mark Kovalsky
It sure looks like the transmission harness isn't plugged in. Every solenoid is showing an open circuit.
Old 10-06-2009, 01:21 AM
Toreador_Diesel
Retired Mod
Thats about what I figured too....
finn12
33
02-25-2017 01:19 PM
RDockery
1997-2006 Expedition & Navigator
04-21-2016 08:50 PM
snaponprofile
29
04-17-2011 01:27 PM
whack&stack
19
04-07-2011 10:14 AM
shyaam
20
11-28-2005 12:36 PM
Quick Reply: Trans O/D light flashing
