od light flashing
Old Jan 24, 2017 | 10:28 AM
finn12's Avatar
finn12
od light flashing
1997 f250 7.3 drawing a code 124 replaced the tps no effect od light flashing and erratic shifting!what is the procedure for checking the 3 wires from the tps. thanks.
Old Jan 25, 2017 | 03:12 PM
madpogue's Avatar
madpogue
What do you mean by a "code 124"? All the codes should be 5 characters long.
Best way to test the TPS is to use whatever device you're using to obtain codes and set it up to read live data, and check Accelerator Pedal Position % and Accelerator Pedal Positon Volts. Operate the pedal and watch the numbers. You can do this key-on engine-off if you want.
Old Jan 29, 2017 | 05:47 AM
finn12's Avatar
finn12
Ok, I am using an actron obd2 to try and get codes. when i check for codes i get error data link connection. no codes . but on the state check I get 124. I can not read live data. I tried 2 other obd2 meters. the same thing.
Old Jan 29, 2017 | 09:08 AM
madpogue's Avatar
madpogue
So if you couldn't obtain a code, on what basis did you replace the APS?
Not sure what you mean by "state check", but the truck is not standard OBD-II. You need a device that will communicate with the "Ford Enhanced" protocol. Common options:
- Stand-alone plug-in - Snap-On MT2500 with the right cables and K2-A key
- Dash gauge format - AeroForce Interceptor
- PC/laptop - AutoEnginuity, or some folks have gotten Forscan (free) to work with USB/Bluetooth ELM327 dongles
- Android devices - USB/bluetooth dongle with Torque Pro (live data) and Car Gauge Pro (diag codes) apps
I've gotten a ScanGauge II (rectangular dash-top device) to read some live data, but it will not obtain codes.
The other obvious option is to pay the dealer to obtain codes.
Old Jan 29, 2017 | 10:10 AM
finn12's Avatar
finn12
Thank you which scanner do you recommend?i will go from there.
Old Jan 29, 2017 | 11:03 AM
madpogue's Avatar
madpogue
See above. No one is "better" than the others, it depends on the format you want.
Old Jan 29, 2017 | 11:04 AM
finn12's Avatar
finn12
I
will order one and let you know what happens,Thanks Frank
Old Jan 29, 2017 | 05:48 PM
fordpride's Avatar
fordpride
124 is a tps code
Old Jan 29, 2017 | 11:12 PM
madpogue's Avatar
madpogue
^^^^^ On a PSD?
Old Jan 30, 2017 | 06:55 AM
finn12's Avatar
finn12
I am not sure what psd means . I am looking at a auto ingenuity spo3 ford enhanced. I think i am going to order it. What do you think?
Old Jan 30, 2017 | 07:44 AM
finn12's Avatar
finn12
psd for a powerstroke?
fordpride's Avatar
fordpride
Originally Posted by madpogue
^^^^^ On a PSD?
No....that's what is confusing me 124 is a obdI code for gasser
Old Jan 30, 2017 | 08:51 AM
finn12's Avatar
finn12
I am beginning to think the new module has to be re-flashed. does it have to be done at the dealership?!!!!!! or can it be done at a local truck repair shop?
Old Jan 30, 2017 | 09:27 AM
knottyrope's Avatar
knottyrope
Dealer and Some of the tuners can flash PCMs
not many local shops will not even know how to work on it
Old Jan 30, 2017 | 11:44 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Or you could get a later model pcm on ebay and sell your older model one to cover the cost...
