Flashing OD light
Old Apr 4, 2011 | 11:10 PM
whack&stack's Avatar
whack&stack
Flashing OD light
ok fellas tranny is shifting at odd times from 2nd to 3rd and 3rd to 4th and the OD light is flashing. any ideas what is going on?
Old Apr 4, 2011 | 11:15 PM
BuckHammer's Avatar
BuckHammer
It sounds to me like your speed sensor is bad.
Old Apr 4, 2011 | 11:22 PM
whack&stack
thats what i was thinking i havent had the code read yet as the od light just started flashing tonight
Old Apr 4, 2011 | 11:34 PM
BuckHammer's Avatar
BuckHammer
Get the code if you can. Hope it's a speed sensor because they're cheap and easy to replace.
Old Apr 4, 2011 | 11:38 PM
oldbird1965's Avatar
oldbird1965
When mine did that I had to rebuild my trans, hope that's not the case for you.
Old Apr 5, 2011 | 10:04 AM
redman84's Avatar
redman84
Get codes. In the mean time pull out the VSS, clean & inspect it, then replace. Check trans fluid level and smell for burnt smell or odd color. Oh, and get the codes! Good luck partner. May be time for that 5 speed
Old Apr 5, 2011 | 11:03 AM
MADVAN's Avatar
MADVAN
Trans is in limp.
B
Old Apr 5, 2011 | 01:14 PM
rideracelivemx7's Avatar
rideracelivemx7
yes sir, that means the tranny is in limp mode. basically it doesnt know whats going on right now and is upping the line pressure so it doesnt smoke its clutches. Thats why it will shift weird. typically your speedo will stop working when the VSS dies but it may be just be giving bad info to the tcm. in my experience, cleaning the sensor has not done anything for me and there about 25$ from ford FYI. if the VSS is not the issue then you may have a code saying TC slip error or internal clutches issue. and youll know what that means...
Old Apr 5, 2011 | 01:33 PM
whack&stack
I put 35s on it I wonder if that could have tripped up the vss. I bought one vss that is I won't be able to codes till monday
Old Apr 5, 2011 | 01:39 PM
whack&stack
No burnt smell color is good. If I wasn't married I would just swap in a manual but the wife isn't big on spending that money on a truck I drive 2500 miles a year unless its actually needed lol dang women
Old Apr 5, 2011 | 02:18 PM
superduty4x4's Avatar
superduty4x4
No, the only thing that can screw with the VSS is an internal failure or debris stuck to it from ring/pinion wear. Does the speedometer bounce when you drive it?
Old Apr 5, 2011 | 02:34 PM
whack&stack
No that I have noticed
Old Apr 5, 2011 | 02:50 PM
OldGrayMare's Avatar
OldGrayMare
That's exactly what my 97 T-Bird did. Ford dealer wanted $900 to replace wiring harnes to transmission. If you look under the front of the transmission that harness has probably deteriorated on the outside allowing the wires to short together. I took a small vacuum hose split it length wise and placed it over each wire and then taped them shut. Total cost was about $1.85. That was 6 months ago, haven't had a problem since then.
Old Apr 5, 2011 | 03:37 PM
BuckHammer's Avatar
BuckHammer
When my VSS was bad, the speedometer worked fine. Just because the speedometer works, doesn't mean the VSS isn't bad. It's a very inexpensive part, so it wouldn't hurt to change it unless you're really strapped for cash.
I see your truck's on 35s. What is it geared at? I know big tires can kill transmissions if the gearing is not adjusted.
Old Apr 5, 2011 | 09:05 PM
oldbird1965
Whack, just tell your wife your little boss (daughter) will be heart broken if she can't ride in your truck. Most of the time the frontal approach doesn't work, LOL.
