overdrive cancel switch...?
I just did a koer code pull on my 95 f150, 351, e4od trans. I got a code 632- overdrive cancel switch not changing state... I did a koeo test and got a 452-vss/psom code. are these two related? if I change the tps, psom, and the vss will this most likely fix the 632 code or am in to a whole new thing here? any advice would be greatly appreciated, thanks
First let me say I am not a transmission expert, especially on the E4OD. There are some real experts that visit here regularly and may chime in.
However I think your 632 code is because you didn`t push the OD button correctly during the test.
The 452 does seem to indicate a fault with the speed sensor. You could try taking it out and cleaning it and check the wiring to it, including the plug connector and the wiring right down the left frame rail. When you have it out if you remove it completely and hold it away of any metal objects I think (memory not good) it should measure around 200-500 ohms if good. Also when you have it out try to see in or feel in to see if the exciter ring in the diff is OK.
Hope this helps.
Hope this helps.
on
Though I have been away from the greasy fingernails doing computers for the last 20 years (Thanks M$) so I am way behind on all this new fancy talk and stuff.
-Enjoy
fh : )_~
Yup, Diesels for life, Mostly heavy equipment and trucks, Don't get me wrong, I do them gasser things to ... But only if it goes REAL fast on a closed course!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
I have worked on some agri tractor and harvester diesels some years ago (not thru choice) and have a F250 6.9. When they go wrong I don`t know which is worse, computers or diesels!
GrumpyTroy
11-15-2015 01:44 PM
steve281086
09-18-2015 07:50 PM
hotrod351
11-22-2011 11:13 PM
DrBones[LCD]
09-02-2007 03:04 PM
sweet93gt
1978 - 1996 Big Bronco
23
06-21-2007 01:09 PM
