overdrive cancel switch not changing state e40d
Old Sep 24, 2009 | 04:40 PM
hotrod351's Avatar
hotrod351
got this code, 65 = ford overdrive cancel switch not changing state e40d, does any one know what it means.
Old Sep 24, 2009 | 04:48 PM
quicklook2's Avatar
quicklook2
means your overdrive switch may be broken.
Old Sep 24, 2009 | 05:37 PM
White 97 xlt's Avatar
White 97 xlt
Or, the wires may be broken where the shift lever meets the column... Mine were....
Old Sep 24, 2009 | 05:53 PM
quicklook2's Avatar
quicklook2
which would be broken in my book.
Old Sep 24, 2009 | 06:03 PM
White 97 xlt
YES... But you said switch.. and I said wires and somewhat mentioned where to look!!!!!
Should I shut up and let you run this show?????
Old Sep 24, 2009 | 06:50 PM
quicklook2's Avatar
quicklook2
i was agreeing with you, but you could shut up if you want too.
Old Sep 24, 2009 | 10:38 PM
White 97 xlt
i was agreeing with you, but you could shut up if you want to.
Fixed your spelling for you!!
Old Sep 24, 2009 | 10:47 PM
quicklook2's Avatar
quicklook2
it was not misspelled, just typed incorrectly.
i suppose you have never made a mistake typing, right?
Old Sep 24, 2009 | 11:44 PM
LCAM-01XA's Avatar
LCAM-01XA
Hey kids, enough of this already!
To the original poster - which year is your truck? '89-'91 have the button on the dashboard, no worry about the wires on those but buttons do go bad with use. '92-'96 (well '97 really, for the F250HD and the F350s) have the button on the shift lever, and they are the ones that like to eat the wires down where they exit the shifter, too bad you gotta pull the plastics off the steering column to verify this is the issue.
Old Nov 22, 2011 | 11:13 PM
akuhr93'f150's Avatar
akuhr93'f150
^Holy carp haha ima try to be helpful here. I have learned that that code can just mean you did not push your overdrive button during the KOER test, but I get this code too for I never push it either during the test because my manuals have not told me. If someone knows when your supposed to press it pls lemme know it would be a great help. But as said earlier it could be that your wires are for the button are stripped and shorting out where the shift stick meets the steering column. This is what happened to me and I had to take off my steering wheel and other random parts to get to where the wires for the overdrive switch plug into the harness. I just disconnected it, cut the wires at the short, stripped em and soldered em back together and lastly taped it up and put it all back together. Works like a charm but this may not even be your problem.
Does your overdrive button work correctly?
When mine went it would automatically be off when I started the truck and when I tried to turn it on it would blow my automatic transmission fuse. If this does not happen then this prolly isnt your problem. Lemme know, and if this doesn't help you i hope it can at least help someone else.
2006FOMOCO
Oct 15, 2023 06:12 PM
big ole ford
May 22, 2016 11:06 AM
WWR
1997 - 2003 F150
Dec 24, 2015 05:55 AM
tomsrod
Oct 20, 2015 05:56 PM
ggirten
34
Feb 8, 2006 07:30 AM
