DTC's
DTC's
recently I have had problems with the cold start problem that people say the inductive heat flash will fix. I forgot untill today that my bully dog will read codes here is what I got
po275
Po403
po487
v0760
p1158
what do u make of this. What is the posible fix going to be. Do u think inductive flash will fix it.
po275
Po403
po487
v0760
p1158
po275
Po403
po487
v0760
p1158
what do u make of this. What is the possible fix going to be. Do u think inductive flash will fix it.
po275
Po403
po487
v0760
p1158
Po403 - Exhaust Gas Recirculation Control Circuit
po487 - EGR Throttle Position Control Circuit
You need a new EGR valve IMHO, and have some issues w/ Injector #5
The inductive heat flash will definitely help w/ injector stiction (along w/ using a 5W40 synthetic oil).
v0760 - never heard of a "v" code
p1158 - Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2 (trash code)
The prefixes for DTC's are as below:
B - Body
C - Chassis
P - Powertrain
U - Network
po275 - Cylinder #5 Injector Circuit Low Defective coil
B - Body
C - Chassis
P - Powertrain
U - Network
B - Body
C - Chassis
P - Powertrain
U - Network
bigbubba87
24
07-04-2013 02:46 PM
