1211 Code
1211 Code
Hey guys! I have a 97 psd and i had a guy replace my oil pan for $900. When I went to pick up the truck the bill was $1500 he said he had to replce the two fuel lines in the front of the engine and replaced 2 trans lines plus a brake line. Well had no choice but to pay this crook. I drove the truck home and it ran fine, I started it up the next day end my engine light came on and was running like ****. I called the guy up and took it back he finally got the engine light on and said that it had a code 1211 and said that was a big code. Could have something been knocked around from pulling the engine out?
X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
- DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
- Possible causes:
- incorrect oil or viscosity
- poor oil quality
- gel fuel/no fuel
- low fuel pressure
- damaged IPR valve
- high-pressure oil system leak
- damaged high-pressure oil pump
- damaged PCM
- Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
ok I cleared the codes it came back on. and when it started I heard like a lifter taping in the rear of the engine.Also now i have fuel leaking underneath by the starter.It was 27 degrees out and when the truck warmed up the taping noise has quit.I shut it off and started it again and no code.Then I shut it off waited a couple of hours and started it up again and the light cam back on. now what do you think!
Macmathews
01-28-2015 07:42 PM
Stump Puller
18
07-04-2006 10:56 AM
